Thread: Spare Wheel Bolts From Locking Wheel Bolts
    Regular Member Ben H's Avatar
    Herts\Beds Border
    Default Spare Wheel Bolts From Locking Wheel Bolts
    Just read this on another forum
    on some vehicles, fiat being most prominent in my mind, when you may have to fit your space saver spare, do not use the alloy wheel nuts to secure the wheel.
    most cars come with a little box with four spare wheel nuts in it along with other little tools.
    the reason the shorter wheel studs are in the box is solely to use with the space saver.
    the space saver wheel is much thinner at point of contact with the hub and should the normal alloy studs be used to secure the spare, the studs go too far through into the hubs and will totally destroy the rear brake mechanism inside the rear hubs.
    Surely the bolts which come in our boxes are just the ones removed from the car when fitting aren't they? Have never given this a thought & it sounds it could be quite destructive
    Administrator plasma's Avatar
    On the Forum
    359 Post(s)
    Engine : 150
    Mileage : 74000
    Thinking about theres nothing inside the rear hub for brakes cause it uses calipers and not shoes on the rear drums?????
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    This normally applies to cars with handbrake shoes inside the drums,like the omega.The bolts in the locking bolt box are just standard,so no worries.
    Herts\Beds Border
    Quote Originally Posted by plasma View Post
    That is true, put my mind at ease, mind you I've already used the space saver on the rear with the same bolts
    Still never given it a thought though & could be a usefull piece of information.
    Regular Member James C's Avatar
    Essex
    Engine : 2.8 Turbo
    Whoever posted that is talking b***ocks. The locking bolts are usually the same length as the standard bolts, and as others have said the one's in the box are the standard bolts the locking one's replaced. Besides, why would you only have 4 bolts in the box for a 5 stud fitment?
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    Not really, because on some mercs they give you a set of bolts just to use with a steel spare.
    Regular Member Paddy2bsure's Avatar
    Hertfordshire
    I can testify that the above is not b&**$£ks!
    About 18 years ago I drove a Fiat Strada with Alloys (it was a 105TC, if you know your Strada's). Anyhow, I hit a pothole with one of the alloys (made by Speedline) and the wheel shattered. So I robbed the spare off my mum's Fiat Regata 100S & put it on there - except the alloy wheel bolts from the alloy wheel were too long for the steel wheel... they protruded too far into the hub (it was on the front). It seemed to go on okay, but when I drove off, it made a hell of a clatter. Realised pretty quickly what had happened, but it was too late. I physically couldn't remove 2 of the bolts, as they had been bent & sheared off by the hub. New 2nd hand hub had to go on - not a nice job.
    Essex
    Engine : 2.8 Turbo
    Ok then, I'll refine my statement. If you've got a box marked "locking wheel bolts" with only 4 bolts in it on a 5 stud car, it's safe to say the bolts holding the alloys on will be fine with the spare.
  1. locking wheel bolts
    By GCusdin in forum Suspension, Wheels & Brakes
    Last Post: 8th January 2012, 21:03
  2. locking wheel bolts
    By paul.sessions in forum Parts for sale
    Last Post: 30th January 2011, 22:00
  3. Locking Wheel Bolts
    By Handyandy-UK in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2011, 18:53
  4. Locking wheel bolts
    By shan in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2008, 19:34
  5. Wheel Locking Bolts
    By Brocks in forum Parts for sale
    Last Post: 21st July 2007, 08:49
Vectra c space saver wheel bolts
