Thread: fog light woes
    Regular Member ant6566's Avatar
    gwent
    Default fog light woes
    all week the car has been telling me about a foglamp fault,so this morning i had a look,the 2 spade wires had corroded in the fog lamp unit,so a clean up with emery cloth,and a bit of wd40,it all seems ok now.unit was full of water.drilled a 4mm hole i cap centre as drain.fingers crossed for now
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Might be worth taking cap of the back to air out for a while
    gwent
    will do that,thanks
    13 Post(s)
    Quote Originally Posted by ant6566 View Post
    I tried that, but the hole in the bottom of the cap let in more water when I went through some puddles.
    Best thing is to dry the unit out, then lay a dessicant pouch (moisture absorber) in the bottom of the cap.
    Or fit the snorkel kit. http://www.vectra-c.com/forum/showth...-fog-light-fix
  1. Brake Light Woes - Can Anyone Help?
    By stevebev in forum Electrical & ICE (including SatNav)
    Last Post: 1st June 2011, 21:42
  2. New car woes
    By hack in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2010, 19:58
  3. Side Light woes
    By dwstraining in forum Vectra C / Signum Car Chat
    Last Post: 13th September 2010, 16:53
  4. Mot woes!!
    By the-wizard in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2010, 10:14
  5. 2.2 Direct emission light woes
    By DysonDog in forum Engine & Drivetrain
    Last Post: 7th June 2009, 10:40
