Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: HELP NEEDED: Wiring for retro fitting front fog lights on facelift
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Default HELP NEEDED: Wiring for retro fitting front fog lights on facelift
    Hi all,
    I am retro fitting the front fog lights to our Signum Facelift.
    I have activated front fog lights and used the original harness plus changed the headlight switch to one with front fog light switch but they do not work. I did come across a thread that said I needed to change a wire around on the ECU or something but I cannot find it and didn't save it as a favourite, doh!
    So any help would be appreciated either finding the thread or telling me what wires to change
    thanks
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Wires need adding into UEC I'm sure mate
    maybe that's just Astra/ Zafira tho
    @andy.l maybe of some help
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by Critch View Post
    I am sure it was something like that, wished I could find the thread
    Regular Member Sebastian's Avatar
    Electric Heated Recaro Leather
    39 Post(s)
    Engine : 1.9 DTH
    U need new Uec as well , I have something give me a shout
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    Thinking about it did you already have the fog light plugs in place behind bumper?
    Wirral / ellesmere port
    13 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    if youve added the wiring or have the wiring present and
    connected the plugs to the fogs and activated them then they shud work
    if youve added the wiring for thefogs and connected it to the multiplug under the
    uec then it sounds like ya uec wont support front fogs which in that
    case replacement uec is required.
    advise exactly what youve done and wot you e added exactly
    Northampton
    Engine : A20DTH
    Mileage : 88000
    The wires were there but I am not sure if the previous owner put them in. I am hopping they were there and not retro fitted
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Ok so here's some facts to help:
    I enabled fog lights in the UEC.
    UEC ident code is JH
    part no: 13240246
    When I put the ignition on I get t he check bulb failure for the left fog light bulb.
    Fault codes showing up in UEC are:
    B2698-04 open circuit fog light left
    B2525-04 open circuit fog light right
    Thinking about this do I need to put a fuse in somewhere?
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    If the wires where their remove the relay an feed 12v into the inner of the larger relays pins
    if the fogs come on you know the wiring is ok from UEC to fogs
    then check you have 2 12v on the relay and a good ground on the control
    you may just require a new UEC
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    K4 relay an a 15 amp fuse
    directky opposite the relay
  1. Retro fitting heated seats (front)
    By Keithy in forum Styling
    Last Post: 8th November 2012, 23:11
  2. retro fit fog lights on a facelift
    By N2B in forum Bodywork & Interior
    Last Post: 17th June 2009, 20:44
  3. Retro fitting Xenon headlights - what's needed?
    By Duncan in forum Electrical & ICE (including SatNav)
    Last Post: 15th November 2007, 11:10
  4. Retro-fitting pre-facelift passenger door switch to facelift
    By greeningr in forum Vectra C / Signum Car Chat
    Last Post: 23rd May 2007, 15:58
b2698-04 fault code
zafira mk1 front fog light wiring loom
vectra C b2698-04
vectra C b2525-04
vectra fog light wiring
fitring fog lights to a zafira active
vauxhall zafira 07 1.6 fitting front fog lights
Opel DTC B2698-04
opel b2698-04
