Results 1 to 10 of 15
Thread: 1.8 2003 Vectra. Standard clutch kit or Dual Mass Flywheel?
    Apr 2013
    Wolverhampton, West Midlands
    Trim : SRI
    Engine : 1.9 Z19DTH
    Mileage : 116000
    Default 1.8 2003 Vectra. Standard clutch kit or Dual Mass Flywheel?
    Hi all,
    Thinking my clutch is going on my Vectra C, been told the slave bearing is most likely culprit.
    Does my car have the standard solid clutch kit or a DMF?
    Any advice appreciated
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Solid Flywheel on 1.8's.
    Apr 2013
    Trim : SRI
    Engine : 1.9 Z19DTH
    Mileage : 116000
    Cheers Das, I suppose that's not a bad thing then. I've heard of nightmares with the DMF'S
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 85000
    Yup, although its only the smelly Derv boys that have issues with them, you read very few failures on the petrol's that have them.
    Nov 2010
    East Midlands
    8 Post(s)
    Trim : design
    Hey - less of the smelly
    Apr 2013
    Trim : SRI
    Engine : 1.9 Z19DTH
    Mileage : 116000
    So would I just need to buy a 3 piece standard clutch kit and get that replaced? Think the slave bearing has gone on mine
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 85000
    Yes.
    Apr 2013
    Trim : SRI
    Engine : 1.9 Z19DTH
    Mileage : 116000
    Just a another thought, with my slave bearing being suspect to failing, would this also cause me to have trouble selecting gears? Had problems last night where I lost all gears and couldn't change up or down?
    Nov 2010
    East Midlands
    8 Post(s)
    Trim : design
    If the clutch is not operating properly it will affect your gear changing - Can I ask why you would want to change the flywheel if it was in good order ie not worn/scored? I know a lot will say it's best to change it while the gearbox is off but if it is in good order why - especially a solid flywheel - a DMF yes
    Apr 2013
    Trim : SRI
    Engine : 1.9 Z19DTH
    Mileage : 116000
    Hi, I have been advised that my concentric slave cylinder is on its way out and with the noises I'm hearing and the struggling selecting gears then I'm guessing I will need a complete 3 piece clutch kit change. I wasn't sure if I had a solid clutch set or a DMF that's all. I also wasn't sure if I have gearbox issues as well due to the that fact I'm finding it hard to get gears
  1. For Sale: Dual Mass Flywheel VAUXHALL VECTRA 2.8 turbo 05-08, Z28 NET engine
    By viper8 in forum Parts for sale
    Last Post: 6th November 2012, 08:44
  2. Dual Mass flywheel and Clutch - approx price
    Last Post: 5th May 2012, 16:46
  3. clutch and dual mass flywheel leeds area
    By greza1066 in forum Engine & Drivetrain
    Last Post: 6th September 2011, 08:45
  4. New Clutch and Dual Mass Flywheel
    By vectra2004 in forum Engine & Drivetrain
    Last Post: 5th December 2009, 10:50
  5. cdti dual mass flywheel and clutch
    By andy.l in forum Parts for sale
    Last Post: 14th June 2009, 18:57
which flywheel for a 2003 vectra c 1.8
vectra c 1.8 dual mass flywheel
vectra 1.8 dual mass flywheel
does a 2003 vectra 1.8 have a duel mass flywheel
does a petrol vectra have a dual mass flywheel
1.8 2008 vectra c flywheel
clutch life on vectra c 1.8 2008
vauxhall vectra 1.8 petrol flywheel
