Results 1 to 2 of 2
Thread: Another clutch problem.
    Regular Member owen_999's Avatar
    Aug 2012
    Hartshorne
    Vehicle : Vectra SRI 150
    Trim : SRI
    Engine : 1.9cdti 150
    Default Another clutch problem.
    Well had yet again a clutch problem today.
    Had just parked the car up if be it a little bit poorly and got out to unload when a proper space opened up, so I jumped in to it and went to start it. I had my foot flat on the clutch and it was already in first. Then as I turned the key all I got was a load of grinding a bang and the engine stalled. I restarted the engine and it went smooth like normal. Went to pull away and the biting point was right at the top about. 5mm form the top and as I took my foot of the peddle I felt a vibration and a slipping feeling then when I tried to stop the clutch biting point was below where I could physically push the peddle so had to force it out of gear and the clutch peddle didn't return to the top of its travel.
    I've been told by someone that it feels like the master clutch cylinder has flipped it's seal but how would that explain the grinding and the lake of travel.
    Any help is greatly appreciated.
    Aug 2012
    Hartshorne
    Trim : SRI
    Anybody got any ideas on this? Would really like to go in to vauxhall clued up as I know they are going to try and fob me off
  1. clutch problem?
    By tjr2011 in forum Engine & Drivetrain
    Last Post: 20th March 2012, 18:30
  2. Clutch Problem
    By k3v1n123 in forum Engine & Drivetrain
    Last Post: 2nd March 2010, 16:37
  3. possible clutch problem
    By DonZ1000 in forum Engine & Drivetrain
    Last Post: 2nd February 2010, 09:58
  4. clutch problem?
    By darko2301 in forum Engine & Drivetrain
    Last Post: 10th April 2009, 21:33
  5. Clutch Problem....
    By Whiteknight1973 in forum Engine & Drivetrain
    Last Post: 9th November 2008, 18:13
