have these fault codes;
B0670 airbag telltale circuit malfunction
B1590 passenger mirror vertical position range/performance
B3843 air quality sensor circuit low voltage /
Anybody any ideas how to remove/fix the above ?
B0670 means your airbag light is knackered... Does it come on with the ignition? It may be that the LED has blown or someone has 'modified' it.
B1590 might mean that your nearside mirror has been pushed past its extents?
Can't even guess at B3843 though, sorry.
Will disconnecting battery for 5 mins not clear these ?
Not the airbag one, you need T2 or Opcom to do that.
If the airbag light works fine, then it might be something else. How long has the code been on for?
I honestly couldn't say. If you google the complete fault code (so Bxxxx XX, eg B0670 D2 or whatever yours says) you might find out a bit more info about it.
@plasma says it would be the clocks,and asked if i ad changed colour of them(havnt thou)
i went down the google route first,maybe have to go further back on it
had my clocks go faulty, exactly light that, airbag telltale (i had mine coloured changed by @kman247 ) they developed a fault a year or so later (non-related) new set of clock cleared it, would have 2 error codes i think, one from the instruments saying telltale faulty and also the Airbag ECU complaining about it as well.
