Results 1 to 2 of 2
Thread: inlet crud and wont start
    Regular Member andy_richmond's Avatar
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    Default inlet crud and wont start
    Cleaned the egr. Took off top of inlet, only part with turbo hose on. Think crud came loose. Wont start. Seems no compression. Blocked somewhere??? Best way to start or force it?? 2.2 dti vec c
    Sep 2011
    West Yorkshire
    Take the throttle body off and clean it thoroughly. If sh*t has fallen into the inlet manifold could be bad news. I've personally got a 1.9cdti so I'm not overly familiar with 2.2's, but if the throttle body is clogged with carbon it can cause all sorts of problems. Unbolt, clean, spray egr/inlet cleaner into the inlet manifold and try start again
  1. Wont start :-(
    By GCusdin in forum Engine & Drivetrain
    Last Post: 19th September 2012, 16:39
  2. help please - car wont start
    By mdibb2009 in forum Engine & Drivetrain
    Last Post: 16th July 2011, 12:38
  3. 2.2 cut out now wont start
    By spink1972 in forum Engine & Drivetrain
    Last Post: 22nd April 2011, 08:32
  4. Wont start
    By BigWilko in forum Engine & Drivetrain
    Last Post: 9th November 2010, 19:47
  5. Wont start when below 1C
    By turb0z in forum Engine & Drivetrain
    Last Post: 12th January 2008, 16:34
