Thread: starting problem
    Apr 2013
    sheffield
    Vehicle : vectra c
    Trim : club
    Engine : 1.9
    Default starting problem
    Hello. I'm hoping someone on here can help with an issue I have with a vectra 1.9cdti. When I start the car first time, there's no problem with it starting. When I come to start it a second time after it's been parked up, that's when the problem begins.
    I'll turn the ignition, wait for the glow plug light to go out then try starting the car. It will turn over and keep turning over but won't fir up. I' have to repeat this about at least 3 times before it starts, if I'm lucky.
    After this during the day, it sometimes starts first time or a repeat of starting difficulty. Had it to a garage, the mechanic says it's not the glow plugs or injectors as he's checked these.
    If someone can shed any light on what could be at fault, it would be most welcome!
    Kind regards, karl
    Great forum by the way from what I've seen and read
    With the engine warm and it failing to start, put a multimeter across the battery terminals to measure the voltage whilst cranking. If the voltage drops too low then the starter is drawing excessive current and the ECU will not get enough voltage to read all the sensors properly, and fuel correctly.
    Alternatively, it maybe that when warm the starter is just not turning over fast enough to generate the heat and compression required for the engine to start.
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    Engine : 1.6T SIDI Petrol
    Quote Originally Posted by karld73 View Post
    Kind regards, karl
    @karld73 any update on this? I am going to view a CDTi 150 tomorrow with starting problems.. I only know my way around petrol engines.
    Not sure what would cause this, shame the thread has not been updated as it would be useful to know. Thanks.
    Carnoustie
    I had this problem and it ended up being a lazy starter motor!
    Ronnie
    Regular Member any-mgzt's Avatar
    cheshire
    21 Post(s)
    Trim : basic
    Engine : Z19DT
    I agree with Ronnie63, was the starter on mine
    Mar 2012
    wakefield
    Vehicle : vectra v6 cdti
    Trim : sri
    Mileage : 70000
    Alot of people have this problem especially the cdti 120 and 9 times out of 10 its the starter motor
    Apr 2013
    sheffield
    Vehicle : vectra c
    Trim : club
    Engine : 1.9
    Cheers guys. The last garage I went to mentioned the starter motor sounded a bit lazy on the start. Much appreciated!!
    Regular Member ftm100's Avatar
    South Shields seagull sh*t town
    Mine was same took starter of dismantled,cleaned it ,refitted starts first time now
    Apr 2013
    sheffield
    Vehicle : vectra c
    Trim : club
    Engine : 1.9
    A new starter motor is what was needed. Thank you for your help !!!
    Apr 2013
    sheffield
    Vehicle : vectra c
    Trim : club
    Engine : 1.9
    Starter motor
  1. Starting problem
    By sberrow in forum Vectra C / Signum Car Chat
    Last Post: 9th May 2012, 08:43
  2. starting problem
    By andrewl6527 in forum Engine & Drivetrain
    Last Post: 28th March 2012, 20:14
  3. Problem...? Vectra SXI...problem with starting after filling with fuel?
  4. Starting problem
    By DerekFB in forum Engine & Drivetrain
    Last Post: 19th August 2008, 19:54
  5. starting problem
    By chunkster in forum Vectra C / Signum Car Chat
    Last Post: 16th March 2008, 13:09
