Thread: fault code help code p1565
    Nov 2011
    Newcastle upon tyne
    Exclamation fault code help code p1565
    hi all done the peddle code test thing lol and came up with this code, checked it up and this is what it says
    P1565 interface speed control dysfunction CRC (electronic speed control) B-006
    how and what do i do to resolve this, crusie control hasnt really worked since i got the car 2 year ago and light doesnt come in during ignition as supposed to, any help greatly apreciated
    thank you
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 167340
    hi mate
    i find that if you dont use the cruise control often then the stalk needs a clean
    though lack of use similar to the electric window buttons on the passenger side they also need a clean on the contacts
    click below
    http://www.vectra-c.com/forum/showth...ntrol-problems
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 167340
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 167340
    Nov 2011
    Newcastle upon tyne
    Mine is an 04 mate.
    Tryed the how to earlyer today mate. Unfortinaly no luck. Will turn on for 2 seconds then strait back off. Still no light on ignition as t supposed to be. Bit gutted the quick fix didn't work
    Regular Member AndySignum2.2's Avatar
    Oct 2016
    Trim : 2.2 Direct Exclusiv
    Engine : Not sure
    I'm getting that error code on my 57 signum......the problem first started off as running on 3, so I swapped the one with another and still the same, so I changed the ignition rail and still the same issue, running on 3, so I've got p1191, the p1565 code, u2108, u2139 and 2103.....and this started off as a misfiring on cyclinder 2? That can't be right, I'm wondering if the side indicators that I installed have caused an issue.....they are the thingy repeaters. Before I installed those, there was absolutely nothing wrong with the car. Now the electrics have gone barmy.....any help would be appreciated at this time.
  1. p1792-71 gearbox fault code plus alarm sensor fault codes
    By stu f in forum Vectra C / Signum Car Chat
    Last Post: 13th August 2013, 21:05
  2. Fault code help
    By RBH in forum Engine & Drivetrain
    Last Post: 16th December 2012, 22:46
  3. Fault Code P1565
    By spennny in forum Engine & Drivetrain
    Last Post: 2nd May 2012, 20:50
  4. Fault code P0382 and P1565. Anyone..??
    By Hummelshøj in forum Vectra C / Signum Car Chat
    Last Post: 4th May 2011, 10:01
  5. Fault code
    By bellsjoe in forum Engine & Drivetrain
    Last Post: 23rd May 2010, 22:24
p1565 vauxhall
p1565 vectra c
p1565 opel vectra
z22yh fault code p1565
p1565 opel
p1565 code on vectraP1565vectra code p1565Opel P1565engine code vectra 2003 p1565vauxhall vectra fault code p1565vectra c fault 1565p1565 opel signumzafira b error code 1565vauxhall P1565P1565 OPEL MERIVA1565 vauxhall fault codep1565 opel astravectra c 1.7 code p1565code erreur P1565 opel tigrap1565 merivaOpel fault code 1565Opel DTC P1565-72p1565 opel corsa c z12xepp1565 vectra z22yh
