Thread: New starter motor fitted but now engine turns but wont fire.
    Apr 2012
    Nuneaton
    Unhappy New starter motor fitted but now engine turns but wont fire.
    I went to start my car up yesterday after having the shocks changed that afternoon and got clicking and then nothing. I managed to bump start it and it fired up. I noticed burning coming from the starter and replaced it with a recon unit. This was the same spec and went on with no problems I checked all the connections and when I reconnected the battery and the starter turned it over but it wouldn't start. I am getting 12.5 at the battery and the same down at the starter?? Has anyone got any idea what I check as I checked to ensure I haven't knocked any sensor etc off. Could it be the crank sensor?? I have no idea where this is located though.
    Apr 2012
    Nuneaton
    Vauxhall Vectra 1.9 CDTI 2007
    Regular Member ftm100's Avatar
    South Shields seagull sh*t town
    Possible you could have disconnected crank sensor its just below the starter motor
    Administrator plasma's Avatar
    On the Forum
    549 Post(s)
    Engine : 150
    Mileage : 74000
    just above the starter, lay underneath it and look upwards... you'll half to have a sharp eye, you'll see its probably floating around.
    Apr 2012
    Nuneaton
    I have sorted it I managed to knock the crank sensor off and when I stuck it back on it fired up straight away. Thanks for the replies everyone.
  1. Starter Motor
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 16th January 2014, 13:01
  2. Changed starter motor now wont start
    By andddy in forum Vectra C / Signum Troubleshooting
    Last Post: 12th November 2012, 17:56
  3. cdti 150 turns but wont fire :(
    By toast in forum Engine & Drivetrain
    Last Post: 6th May 2012, 19:22
  4. CDTi turns over but wont fire
    By Malcste in forum Vectra C / Signum Troubleshooting
    Last Post: 1st December 2011, 14:40
  5. HELP! Car wont start, Engine turns over.
    By CDTI120SXI in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd July 2011, 13:57
