Thread: Brake were sensor
    Aug 2012
    South Wales
    Default Brake were sensor
    Hi all just changed the pads and disks all round on the vec and managed to f*** the break were sensor it crumbled as I took it out of the old pads so got warning light on getting new wire in morning but just woundering how the blue end comes out the connector block does it just pull out or what any info be great as I only got tommorow to sort it I know you can connect the ends to trick to sensor but would rather replace it
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    New sensor will just clip in mate
    Jul 2010
    This is London baby
    Vehicle : Dodge Journey
    Trim : SXT
    Engine : 2.0Tdi (VW Engine)
    Year : 2010
    Mileage : 53000
    Normally push in or pull out a lug then pull out the plug.
    Regular Member Lordish's Avatar
    Feb 2012
    Luton
    I had the same but just joined the wires. 10 min jobs and then you don't have to worry about it ever again.
    Nov 2012
    Denmark
    6 Post(s)
    Vehicle : Opel Vectra
    Trim : OPC
    Engine : 2,8 V6
    Mileage : 90000
    there's a brake wear sensor?- what does the warning light look like?
    Jul 2010
    This is London baby
    Trim : SXT
    Year : 2010
    Mileage : 53000
    A circle with broken lines around the outside.
    Nov 2012
    Denmark
    6 Post(s)
    Trim : OPC
    Engine : 2,8 V6
    Mileage : 90000
    the one with the ! inside?
    Jul 2010
    This is London baby
    Trim : SXT
    Year : 2010
    Mileage : 53000
    Can't remember 100% as my pad warning light is bridged, pretty sure there is no symbol inside the circle. Maybe that's for the low brake fluid?
  1. brake pad sensor
    By G19RKE in forum Suspension, Wheels & Brakes
    Last Post: 15th November 2012, 02:00
  2. Fitting & Installation of ABS Harness & brake Help sensor sensor
    By Elahi_786 in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2012, 20:46
  3. Brake pad sensor
    By tubby in forum Suspension, Wheels & Brakes
    Last Post: 26th July 2010, 21:21
  4. Brake pad sensor
    By philjensam in forum Suspension, Wheels & Brakes
    Last Post: 23rd May 2010, 21:53
  5. Brake Pad Sensor.. How far can I go?
    By aaruck in forum Suspension, Wheels & Brakes
    Last Post: 19th August 2008, 19:18
