Results 1 to 10 of 17
Thread: Z19DTH Smokes on start up and idle only.
    Aug 2011
    Dudley
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTI 150BHP
    Mileage : 141000
    Default Z19DTH Smokes on start up and idle only.
    Guys,
    My Z19DTH smokes a little on start up and sometimes on idle and also sounds a bit like diesel knock when it does it. The smoke was only noticed after the DPF removal and remap but the knock was present before removing the DPF and remapping, so its nothing to do with the remap. The instant consumption rises to 0.2g/h when it does it, but its not all the time. It can be ok one day and the next day it will do it every time you pull up at traffic lights etc.
    DPF removed and mapped out
    EGR blanked and mapped out
    No spanner or engine light on
    No fault codes present either
    Data log done when the problem was there but nothing detected.
    I'm now at a bit of a loss with this one, so any advice would be great.
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Vehicle : Vectra C estate
    Trim : SRI
    Mileage : 79000
    hows the inlet looking?
    Aug 2011
    Dudley
    Mileage : 141000
    Inlet manifold was fitted new about 6 months ago, swirl bar is moving and seemed clean when I blanked off the EGR valve.
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 79000
    you could try replacing the injector seals, I did this on a customers car and the smoking reduced quite a bit
    Aug 2011
    Dudley
    Mileage : 141000
    There is no sign of any leaks around the injectors. They may be coming out to be tested at which point I will fit new copper seals. The injector deviations were higher than normal but its not always that way. The fault appears to be triggered by something else which increases the deviations.
    Hanging Heaton
    35 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Where abouts is it coming from, mine does this from the turbo area and I have slight carbon build up on the inlet pipe, been too lazy to strip however as busy fixing other things
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Quote Originally Posted by wheelspin View Post
    Best course of action.
    Aug 2011
    Dudley
    Mileage : 141000
    Guys,
    Just found this for information. This was done a tick over when the engine was up to normal temperature and the engine was knocking and smoking at the same time.
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    5 Post(s)
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    looks like you have a problem with injector 1 I think that the tollerance can be +/-3
    Aug 2012
    South Wales
    With figures like that could be the knock sensor playing up sending duff info to the ecu and causing over fueling hence the smoke and knocking noise
  1. 2.2DTI smokes heavily on start-up
    By jammy_c in forum Engine & Drivetrain
    Last Post: 15th October 2012, 17:06
  2. Lumpy Idle when first start up
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 19th August 2012, 11:11
  3. Replies: 15
    Last Post: 3rd July 2012, 21:14
  4. z19dth breaking belt at idle speed
    By RyanNI in forum Engine & Drivetrain
    Last Post: 21st December 2011, 22:54
  5. Z19DTH won't start
    By selui in forum Engine & Drivetrain
    Last Post: 27th October 2010, 15:22
vectra z19dth idle speed
z19dth knock sensor
z19dth smokes when left
z19dth smoke
