Thread: poor startin on my v6 cdti
    CORBY
    Default poor startin on my v6 cdti
    Hi All
    car starts on the key when cold drive for 30 min norm tem runs sweet pulls like a train
    leave it for an hour or so will not start for love or money been to garage no fault code all clean
    been looking and found that it could be coolant sensor any thoughts ?
    where is the sensor on the v6 cdti 05 reg so i can disconect the plug and see if it will make and change to the starting problem
    had the car for 5 yrs now got it with 25k on now with 137k and it the first time it let me down
    thanks for your time to help
    Sounds to me like the battery is nearing the end of its life, as I noticed mine was very poor starting over when cold or after a short run
    Is it is still on the original?
    If so, get a DIN reading
    Ironically, we have cars of almost identical age and mileage...
    CORBY
    Hi m8
    Put jump leads on still no joy
    Quote Originally Posted by jonsi View Post
    This confirms the battery has failed and no longer has a high enough DIN rating to start the engine
    You are not supposed to use jump leads on the V6 CDTI
    It is clearly stated in the handbook and anyone that has ever asked me for a jump start I have refused
    A jump start should only be performed when the battery is flat and the engine won't turn over
    You connect to one of the terminals on the (failed) battery and the other to the engine earthing point
    When the battery on mine failed it took the dealership three attempts to start the engine, and the technician that normally deals with my car pointed out where they had gone wrong
    I then had to call out the AA and this person had the same problem, and I pointed to the earthing point
    CORBY
    new battery still the same :-(
    Regular Member pogo's Avatar
    Feb 2006
    Growing old disgracefully!
    Vehicle : Vauxhall
    Trim : Astra gtc vxr
    Engine : 2.0 turbo
    Tbh it sounde to me a bit impausible that it was battery causing this prob,hope you get sorted mate
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Need live data to see what's going on tbh
    coukd be a number of things. Temp sensor, leaky injectors, poor fuel etc etC
    as for waiting for the battery to be completely flat before jump starting.
    thats a sure fire way of killing ecu
    as for jumping at engine earth that's standard practise.
    ill jump started 100s of cars and be we had a problem
    used my v6 to jump start plenty of cars too.
    abyway back on topic.
    to op best get would be a live data comparison.
    rail pressures, temps etc from when it starts ok to when it won't.
    IMO this isn't an engine to be guessing at parts.
    purely for their price an complexity to access.
    you want to be sure your right
  1. Very poor performance 1.9 cdti
    By uk300bake in forum Engine & Drivetrain
    Last Post: 8th August 2012, 16:08
  2. Why am I getting such poor MPG in my CDTi?
    By daveb1971 in forum Engine & Drivetrain
    Last Post: 23rd July 2011, 08:34
  3. 1.9 cdti 150 now poor economy
    By xiodene in forum Vectra C / Signum Car Chat
    Last Post: 26th November 2010, 19:37
  4. 2004 2.0 dti startin prob
    By ryan_c_dti in forum Engine & Drivetrain
    Last Post: 6th September 2010, 22:30
  5. help! 2.2 direct startin problem.
    By shakey in forum Engine & Drivetrain
    Last Post: 2nd December 2009, 18:04
