Results 1 to 10 of 16
Thread: Brake lights Flashing Constantly
    Mar 2013
    Wiltshire
    Engine : 1.9 CDTi
    Default Brake lights Flashing Constantly
    Got told last night that my Brake lights are constantly flashing. I checked this evening and they flash like strobe lights ( all 3 lights ) and light up normally when the brake pedal is pressed. Had a warning light pop up as well that said Brake Lights Switch. Im assuming the pedal switch is faulty. Any1 had this issue ? ( Vec C 07 150cdti ) Cheers
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 167340
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Pretty certain they're only supposed to do that if you break heavily above a certain speed... such as hitting the anchors on a motorway... as an additional warning. As you suggest though I'd be looking at the switch first - given the amount of work it gets, it's a prime candidate for failure at some point... although if you're lucky it may just be dislodged of have a loose connection.
    Vehicle : .
    Trim : .
    Engine : .
    Year : .
    I'm sure they are only meant to flash when the ABS kicks in.
    Sent from my iPhone 5 using Forum Runner
    South east
    Are you sure they haven't got non-Canbus compliant bulbs in there, perhaps LED ones?
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Have you changed bulbs recently?
    seen a few similar problems with incorrect bulbs
    brake pedal switch could also be at fault
    Mar 2013
    Wiltshire
    Engine : 1.9 CDTi
    I was sat in the car outside and they were doin it then with engine running, did notice tho that wen the car is started the lights light up and stay on for 5 seconds then start to flash.
    No bulbs Changed at all - just started happening last night.
    Switch is the 1st port of call on the weekend.
    Oct 2006
    North Yorkshire
    Vehicle : Astra
    Trim : GTC VXR
    Engine : 2.0 Turbo Petrol
    Year : 2015
    Mileage : 3,200
    They ment to strobe when braking hard and Abs kicks in as mentioned above. Same thing on the Insignia
    Mar 2013
    Wiltshire
    Engine : 1.9 CDTi
    the problem isnt under braking, its doin it constantly parked up or driving under normal braking.
    Also having this fault with the car at the same time
    http://www.vectra-c.com/forum/showth...-under-Braking
    Regular Member stret's Avatar
    Oct 2012
    east midlands/westmidlands
    28 Post(s)
    Vehicle : signum
    Trim : elite
    Engine : 1.9 cdti 16v 225bhp
    Year : 54
    Mileage : 150k
    if you have or have access to opcom or vauxcom/tech2 you can check the switch functionality with it in output tests
  1. Tail lights constantly on...
    By Neve'o in forum Vectra C / Signum Car Chat
    Last Post: 23rd February 2016, 20:13
  2. flashing brake lights????
    By mike. in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2012, 10:58
  3. Light for Glow Plugs Flashing Constantly
    By SWILSY in forum Engine & Drivetrain
    Last Post: 1st April 2011, 15:51
  4. Flashing brake lights
    By jsr645 in forum Electrical & ICE (including SatNav)
    Last Post: 5th October 2009, 20:55
  5. Flashing brake lights
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2008, 20:51
vectra c brake lights flickering
vectra flickering brake lights
vauxhall zafira brake light flashing
brake lights flickerimg vec c
corsa c brake lights flickering
Astra h flashing brake light problem
why do my brake lights keep flickering on my corsa uk
vauxhall zafira brake lights flickering
