Thread: QUESTION FOR MOT TESTERS: Broken headlight on Fiat Ducato
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Default QUESTION FOR MOT TESTERS: Broken headlight on Fiat Ducato
    Hi,we have a fiat Ducato motorhome. Unfortunately a stone has hit the headlight and punched a hole through. Would this fail the MOT?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    I'm no MOT tester, but I'm guessing it'll be a fail, as the beam pattern will be affected, and there will be a sharp edge?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I am thinking the same, a new headlight is £200 if you can get one
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Found this?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Yes I am watching that already
    Engine : 1.9 CDTi
    If it has a sharp edge yes but if you smear clear silicon over it it will pass as it wont effect the beam hardly at all.
    Dec 2012
    Southampton
    Ring a windscreen fitter and ask if it's possible to clean and resin patch.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Ok so on close inspection there are no sharp edges. There is a piece of glass laying inside the headlight tho so it does not look like it can be resin patched
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Get a bit of silicone in it and it should be fine.
    as it will have minimal effect on light beam
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I found some all weather clear tape and put a square over it for the time being to stop water ingress
  1. ADVICE NEEDED: Head unit too deep for my Fiat Ducato Van
    By merikiito in forum Electrical & ICE (including SatNav)
    Last Post: 4th April 2013, 22:19
  2. Headlight Question for the MOT Testers Amongst Us
    By Rebellion in forum Vectra C / Signum Car Chat
    Last Post: 18th November 2012, 16:48
  3. Non Vectra post-Fiat Ducato Van
    By Steves-Vec in forum Engine & Drivetrain
    Last Post: 12th January 2011, 22:34
  4. Question for any MOT testers out there...
    By damian s in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2010, 21:53
  5. fiat croma question
    By solorider in forum Vectra C / Signum Car Chat
    Last Post: 22nd November 2008, 12:41
