Hi All
Can anyone advise where the O2 sensors are ?
Are they easy to change
2.2 Direct
06 Reg
Paul
Sent from my iPhone 4s using Forum Runner
Hi All
2.2 Direct
06 Reg
Paul
Should be one pre cat and one after the cat iirc.
buypartsby is now my new favourite website, thanks.
Are they a DIY job ??
there easy enough to do fella but unplug them before you undo them
Best getting a O2 sensor socket saves a lot of problems
Agree 100% - an open ended spanner WILL slip and round the sensor off if its tight and been in there a while. A O2 sensor socket (22mm IIRC) is a 6 sided socket with a slit in so you can get it on the sensor accommodating the wire. I wont change one without using my set now.. Rounded off too many - and too much hassle to then heat / grip / remove etc. Also - don't contaminate the sensor end of the new one with ANY fluids that you may use to spray the old one before removing - like WD or plus gas etc... Keep it covered literally until you insert it.
I changed my rear O2/lambda sensor last weekend. The from one is very simple. The rear one has a long cable from the sensor to the engine which goes through little gaps. I done mine myself. Jacked it up. Used mole grips to undo it ( bit of a struggle but got there in the end) and fed it back through the gaps. Not too difficult and it was worth it. You can buy ones that come as a whole or one where you have to connect them up yourself.
