Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: NCDC2013 to CD70 in a half can pre-face Vectra
    North West - Assistant RO Woody's Avatar
    May 2012
    North West (Warrington)
    234 Post(s)
    Vehicle : Vectra C 3.2 Elite Estate Auto Facelifted
    Trim : Elite with loads of "Extras"
    Engine : 3.2 Z32SE
    Mileage : 94,000
    Default NCDC2013 to CD70 in a half can pre-face Vectra
    Well, it's in and working I'm now like a dog with 2 **cks
    All thanks to lots of hours and head scratching by Robsey and caused mainly by a really amateur Parrot installation carried out by an apparant cowboy who really made a mess of the wiring and some faulty cabling.
    The CD70 has everything functioning, scroller wheels, full board computer functions including average fuel and fuel remaining and, when I can make my way to someone who can provide help with a tech2, it also has Rear Seat Audio wired up & fitted but just needing programming.
    @Robsey you are a STAR mate and all your knowledge, efforts and research and wiring and head scratching and re-wiring more than once only to discover a faulty cable was the culprit all the time are ALL very much appreciated fella
    The mods included rewiring and adding can lines, converting cabling, fitting scroller switches and programming for scrollers and the board computer fuel use, and of course wiring up for RSA !!
    Additionally the ECC unit needed switching to the full can version, and the centre dash speaker needed changing from the twin speaker version used by the NCDC2013 to the single speaker used by the CD70.
    Robsey, you are a genius retrofitter and a guy who has done what others had said couldn't be !
    Many thanks fella
    Woody
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Nice one i want this done but will need a how2 lol
    VXR where are you now
    16 Post(s)
    Vehicle : Nissan GT-R R35 Vectra XP2 CDTI
    Trim : Nissan GT-R R35
    Engine : 3.8 twin turbo 700hp
    Year : 2010
    How 2 how 2 how 2 how 2 please
    May 2012
    234 Post(s)
    Engine : 3.2 Z32SE
    Mileage : 94,000
    I'm sure @Robsey will be along with a how2 when he has had time
    Incidentally, if you are considering this mod and find a suitable donor car, don't forget the centre dash speaker, also, as was said previously, if your pre-face has half can electronics and an Electronic Climate Control (ECC) then you will also need to swap the ECC for a faclift full can model. The part number of the facelift ECC I used was 13131021.
    Woody
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Did you have to take the dash out to do this ?
    May 2012
    234 Post(s)
    Engine : 3.2 Z32SE
    Mileage : 94,000
    Quote Originally Posted by Mark-R View Post
    No, it's only the dash control unit. It's a module that just slides in similar to how the radio does except that it unclips in the same way that the cubbyhole does. Two large plugs on the back, unplug, swap units and replug and that's it.
    In fact, that, probably along with the dash speaker, are probably the easiest bits of the job
    milton keynes
    Well done guys , its not the easiest mod to do , but satisfying when it is completed.
    Regular Member ThatAudioBloke's Avatar
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    Did fitting the CD70 single-coil speaker fix the distortion issues as well?
    Regular Member Niall83's Avatar
    Nov 2009
    Belfast
    Trim : Exclusive
    Engine : 18VVT Z18XER
    Mileage : 130k
    Wow great job.
    May 2012
    234 Post(s)
    Engine : 3.2 Z32SE
    Mileage : 94,000
    Quote Originally Posted by BoostPuppy View Post
    No it had nothing to do with the centre NCDC speaker because that had been unplugged from the loom at an early stage.
    Today we went to start by reversing the radio output wiring via the quadlock so that the rear audio powered the front speakers and vice versa. During the wiring change Robsey discovered a badly made connection so the wire was replaced. Anyway, perfect audio once the reversal was done, and when it was put back to as it should be, again perfect audio.
    So, all down to a dodgy connection on the quadlock conversion lead which was purchased retail and had a few additional wires added.
    It was really frustrating and consumed a lot of time, but very pleasing to see that everything had been done correctly. I know @Robsey was as chuffed as I was. He was the one scratching his head, I was the one blowing the moths out of my wallet wondering if I might need a new headunit LOL
  1. Swap NCDC2013 with CD70
    By Teapot in forum Electrical & ICE (including SatNav)
    Last Post: 4th January 2013, 01:41
  2. is it possible to fit a cd70 into a half can 2004 signum ?
    By deano1 in forum Electrical & ICE (including SatNav)
    Last Post: 6th October 2012, 08:21
  3. What radio's can go into Half Can models 03 pre-face
    By MURDO in forum Vectra C / Signum Car Chat
    Last Post: 15th August 2012, 16:39
  4. CD70 screen in a 04reg preface half canbus
    By andyman201 in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2010, 14:43
  5. Cd70 & Ncdc2013
    By gtr1000 in forum Electrical & ICE (including SatNav)
    Last Post: 26th December 2007, 18:34
half can to full can vectra c site:www.vectra-c.com
cdr2005 pinout facelift prefacelift
