Results 1 to 10 of 11
Thread: Unresponsive parrot MKI 9100?
    Regular Member Henry42's Avatar
    Jun 2011
    South Shields
    Default Unresponsive parrot MKI 9100?
    Morning all, i have had fitted a parrot mki9100 for about 9 months now with no issue, now all of a sudden its become completely unresponsive, dosent power up, wont turn on, no lights come up, Iphone wont pick it up.
    Was toying with the idea of going back to were i bought and had it fitted, but thought i would see first if anyone else has had this problem.
    Thanks in advance.
    VXR where are you now
    16 Post(s)
    Vehicle : Nissan GT-R R35 Vectra XP2 CDTI
    Trim : Nissan GT-R R35
    Engine : 3.8 twin turbo 700hp
    Year : 2010
    if its not powering up it sounds like a fuse has popped fella have you noticed anything else not working?
    North West - Assistant RO Woody's Avatar
    May 2012
    North West (Warrington)
    234 Post(s)
    Vehicle : Vectra C 3.2 Elite Estate Auto Facelifted
    Trim : Elite with loads of "Extras"
    Engine : 3.2 Z32SE
    Mileage : 94,000
    , also have you checked the battery in the Parrot remote ?
    EDIT - It's not the remote that isn't working
    16 Post(s)
    Year : 2010
    he said its not powering up bud not that the remotes not working
    Regular Member ThatAudioBloke's Avatar
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    If the radio still works but the parrot doesn't, it's either one of the barrel fuses on the parrot loom as suggested above, or these have been known to have intermittent connection issues between the screen and the screen dock. This would give the symptoms you have suggested as the kit won't boot up at all if the screen is not seated correctly.
    Easy to fix, take the screen off the mount, ensure the screen and mount connections are clean and fit them back together. Make sure the screen is completely pushed home and it should boot if that was the problem.
    Worst case scenario is that the blue box is knackered, but try the easy things before falling back to that. If it's only 9 months old, it'll still be well within its warranty period so failing the basic checks, take it back and get the installer to sort it for you.
    16 Post(s)
    Year : 2010
    Quote Originally Posted by BoostPuppy View Post
    and trust me hes a man that knows everything about these things...
    Jun 2011
    South Shields
    No everything else is working fine mate.
    Jun 2011
    South Shields
    Quality, thank you very much for the advice, will give it a go tonight!
    Jun 2011
    South Shields
    BUMP!!!
    Afternoon Fellas! still having the same issue, anyone know the Fuse number for the parrot itself?
    Feb 2011
    Selby
    The Parrot has it's own fuses, in the loom. It takes it's power from the normal radio feed (through the ISO connectors). So if the radio's working but the Parrot isn't, then it's likely to be one of these fuses rather than one of the Vectra's fuses.
  1. Engine feels Dull and Unresponsive
    By thompo5 in forum Engine & Drivetrain
    Last Post: 9th January 2011, 14:01
  2. Parrot Mki 9100 arriving 2mara, got last few questions
    By ishaqmir in forum Electrical & ICE (including SatNav)
    Last Post: 20th May 2009, 22:32
  3. Parrot HELP!!!!!!!!!!!!!!!!!!!
    By Jamie in forum Electrical & ICE (including SatNav)
    Last Post: 31st March 2007, 15:18
  4. Car installation for QTEK 9100?
    By G.O'Rilla in forum Electrical & ICE (including SatNav)
    Last Post: 19th March 2007, 19:01
parrot mki9100 screen not working
parrot mki9100 not working
parrot mki9100 not turning on
parrot mki9100 problems
parrot mki9100 wont power onParrot mki9100 reboot loopparrot mki9100 stopped workingparrot mki9100 no displayparrot 9100 screen not workingparrot mki9100 does not turn onparrot 9100 throublesparrot mki9100 bluetooth not workingparrot bluetooth mki9100 wont power onparrot mki9100 no powerparrot mki 9100 fuseparrot mki9100 display not workingparrot mki9100
