Thread: would this be easier(arb bushes fitting)
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    5 Post(s)
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    Default would this be easier(arb bushes fitting)
    When changing the front ARB bushes,would it be easier to just undo the 2 bolts nearly all the way and just slide the old one out and the new 1 in without having to take any of the bolts out?
    Of isnt it that easy?
    Regular Member happypostie's Avatar
    Slough
    130 Post(s)
    Vehicle : insignia vxr
    Trim : vxr
    Engine : 2.8 turbo
    Year : 61
    Mileage : 38000
    Quote Originally Posted by justin32 View Post
    yes im sure that is how bob did his , as it is a pain to get the bolts back in if you take them out .
    Regular Member veclee's Avatar
    Nov 2012
    skegness
    Vehicle : vectra c
    Trim : club
    Engine : 1800
    Mileage : 63000
    Hard work that way you need to remove front bolt completly then undo back bolt by 5-6 mm slid bar forward bracket pops off bush off bush on refit same way about 15-20 mins a side
    Jun 2012
    Doncaster
    Do the bolts for the brackets go into a welded but or do you need to try and get a spanner underneath on the nut??
    Dec 2010
    Cambridge
    Vehicle : VectraC CDTI 150
    Year : 07
    Mileage : 175000
    Welded nut endeed
    Jun 2012
    Doncaster
    Sound thought it looked a bit awkward if it wasn't! Anyone know the bush size on a 1.9 cdti pre face Sri?
  1. Help-Antiroll bar bushes fitting.
    By installer in forum Suspension, Wheels & Brakes
    Last Post: 19th May 2019, 21:59
  2. What is easier.....
    By ridgers84 in forum The 'Off Topic' room
    Last Post: 3rd May 2012, 19:48
  3. make's it breath easier.....
    By ditchp in forum Diesel Engine related
    Last Post: 22nd September 2007, 20:39
