Thread: Warning light stays on
    wigan
    Angry Warning light stays on
    Just changed my dud bulb because my warning light came on but my warning light stays on is there a way to reset this vectra 1.8 2004 any advice plz.
    Regular Member andy-j's Avatar
    Apr 2008
    stoke on trent
    Are you sure there isn't another bulb gone?
    wigan
    no andy they all working fixed the dud bulb now it wont go off.
    13 Post(s)
    As I said in reply to your duplicate post elsewhere
    Check your brake lights.
    If the upper tail/brake light fails, then the lower tail light takes over the role of tail/brake light instead.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    If its LED, u'll need canbus cancellers otherwise check brake lights as said by others. Even it may seem ok it could not be!
    Brake on will show on furthest of each side, inner is sidelights, if main brake light stops functioning, the sidelights become sidelight AND brakelight.
    So check all of them!
    Warning light should go off on next startup after it ran bulb checks after turning car off or at start up,
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 167340
  1. numberplate light stays on
    By skip85 in forum Electrical & ICE (including SatNav)
    Last Post: 24th January 2013, 17:25
  2. Petrol Warning Light Stays On
    By seanp in forum Electrical & ICE (including SatNav)
    Last Post: 16th January 2012, 14:03
  3. Spanner Warning Light Stays On
    By Englishman in forum Vectra C / Signum Troubleshooting
    Last Post: 8th May 2011, 01:00
  4. Spanner warning light stays on
    By NeedleSharp in forum Vectra C / Signum Troubleshooting
    Last Post: 30th April 2011, 15:12
  5. Car and spanner light now stays on?
    By danny1992 in forum Engine & Drivetrain
    Last Post: 7th December 2010, 14:04
vauxhall vectra bulb warning light reset
reset bulb warning light vectra
