Thread: Signum interior display
    Apr 2013
    Somerset
    Vehicle : Vauxhall
    Trim : Signum
    Engine : 2.2
    Default Signum interior display
    Hi guys, when I picked up my signum tother week it didn't have the standard head unit in it , it had the ripspeed DVD player instead , so now the display can't be controlled at all with the buttons on the stick, help
    Regular Member ThatAudioBloke's Avatar
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    Can't do much of anything with those - they don't have a steering wheel input on them.
    Choices are: install an original vauxhall radio, or buy a branded aftermarket radio with steering wheel control compatibility and a third party steering wheel control loom and patch.
    At a pinch, if you just want the steering wheel controls working for the display, you could buy the steering wheel control loom and still use the ripspeed one, but it's a bit of a waste of time since you won't have the volume control etc working from the wheel, only the BC functions.
    Apr 2013
    Somerset
    Vehicle : Vauxhall
    Trim : Signum
    Engine : 2.2
    Do I need the correct cd player for it to match the screen? Usually they are all sold in pairs on eBay? Plus the correct one for model?
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    If you're going back to OE, it's certainly easier to buy them as a married pair. That way they're fit and forget.
    If you get them separate, you'll need the code for the radio, then have the display married to it which is a bit more hassle.
    Depending on how old your car is, you'll either need a 4 digit radio or a 2 digit radio. You can retrofit a 2 digit into an older car but it's not a straightforward plug in job.
    Generally, if your car is a facelift model, you'll need a 2 digit radio (CD30, CDC40 or CD70). If it's an early car (2002-2004) it'll more than likely be a 4 digit radio (CDR2005, NCDC2015 etc). Some of the facelift cars around 04/54/05 reg were full-can, so may have a 2 digit radio. Easiest way to check is to remove the ripspeed one, and have a look at the plug on the wiring loom.
    If the plug looks like this one, it is a 4 digit radio that you need:
    Whereas if it looks like this, it's a 2 digit radio that you need:
    (the plug fits into this socket, so imagine a mirror image of it. I can't find a decent picture of one unfortunately, but it looks drastically different from the alternative 4 digit plug)
    Hope this helps.
    Regular Member Hue Jarse's Avatar
    May 2012
    Farnborough, Hampshire
    Engine : 1.8 VVT (Z18XER)
    Year : 09
    Quote Originally Posted by BoostPuppy View Post
    Something like this
    40 pin Fakra (Quadlock)
    Apr 2013
    Somerset
    Vehicle : Vauxhall
    Trim : Signum
    Engine : 2.2
    Thanks a lot pal will look tomorrow morning and get back to you to let ya know
    May 2012
    Year : 09
    I see from your profile that your car is a 2003 so it is almost certain to be the type in the first picture in Boostpuppy's post.
    Apr 2013
    Somerset
    Vehicle : Vauxhall
    Trim : Signum
    Engine : 2.2
    Just looked on eBay , the cdr2005 ones come with the small display screen and I have the bigger screen if you know what I meen, and ncdc is the sat nav version which is bugging me a bit, the year of mine is 2003
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    http://www.ebay.co.uk/itm/Signum-vec...item19db4ebf4d
    That one should fit yours, and it comes with the code. I also remember reading something about the earlier displays not being coded to the radio but unfortunately I can't say with 100% certainty if yours is or not.
    Regarding your screen, it'll probably be a BID or a GID. Have a look on this thread (http://www.vectra-c.com/forum/showth...-Abbreviations) for pictures of the possible options. If yours is an early screen that doesn't need to be married, then something like that CDR2006 will just plug in and work. Fingers crossed it is!!
  1. Signum Dash Display Problem
    By sol in forum Electrical & ICE (including SatNav)
    Last Post: 28th May 2012, 09:50
  2. Interior heating light display
    By Elahi_786 in forum Electrical & ICE (including SatNav)
    Last Post: 28th December 2010, 20:56
  3. Interior display
    By jon ixi in forum Styling
    Last Post: 17th March 2007, 11:39
