Results 1 to 10 of 11
Thread: Airbag ECU fault code B1000 (c5).
    Apr 2013
    Wokingham
    Trim : LS
    Engine : 2.0 DTI
    Default Airbag ECU fault code B1000 (c5).
    Hi all,
    sorry my third post is a request for help.
    So i had an airbag light on, which after having the codes read, came back with a B1000 fault (ecu failure).
    The trouble im having (after buying a second hand one off ebay and finding i need the exact same one as the faulty one , i know, i know) is finding one that matches my car/part number. I have come across loads of ecu's but not one is the same. The part number is 13142540.
    My question is, if i find one with the same amount of pins would it work, or are there compatible (same ecu, different part number) ecus about. I find it hard to get my head around the amount of different airbag ecu's i have come across, but have yet to find one with the same part number.
    Vauxhall want £440 for a new one, which just isn't an option for me at the moment.
    General info: Cleaned all contacts just in case. Had the codes read again just in case. Car is a 2003 DTI LS.
    Any help would be greatly appreciated.
    Administrator plasma's Avatar
    On the Forum
    548 Post(s)
    Engine : 150
    Mileage : 74000
    Do you know the ident code of yours? It may help others in pointing you in the right direction.
    Apr 2013
    Wokingham
    Trim : LS
    Engine : 2.0 DTI
    Sorry to sound stupid, but where would i get that from?
    On the Forum
    548 Post(s)
    Engine : 150
    Mileage : 74000
    its on the top of the airbag ecu itself. i'll see if i can google that part number and find it out.
    Apr 2013
    Wokingham
    Trim : LS
    Engine : 2.0 DTI
    Its GP i believe.
    On the Forum
    548 Post(s)
    Engine : 150
    Mileage : 74000
    i believe that too
    Apr 2013
    Wokingham
    Trim : LS
    Engine : 2.0 DTI
    Problem solved. I found a replacement part. Turns out the ecu i was after was superseded by another part. For future information, just in case someone ever has the same problem the part numbers are as follows..
    Original Airbag ECU Ident: GP Part Number: 13142540
    Compatible ECU Ident: CL Part Number:13129843
    Hope this helps someone
    Regular Member NealM's Avatar
    Mar 2007
    Cheshire
    Vehicle : Pre-Facelift
    Trim : LS
    Engine : 1.8 Petrol
    Massive thanks to @Slicky for the above information relating to a replacement Airbag ECU and to @Steven T Davies-Moss for the "How To" which can be found HERE. . . I can confirm that for me this HAS all worked . . Very Happy ! !
    Apr 2013
    Wokingham
    Trim : LS
    Engine : 2.0 DTI
    Glad it was of some help
    Jun 2013
    Lancs
    Vehicle : DTi
    Trim : LS
    Engine : 2.0
    Year : 2002
    Hi, all. I have the same error code for my 2.0 DTi Vec C. I also have the part number GP13142540.
    If I find one with the same part number, can I simply plug in and continue or does it need coding with my data? I have spoken to various “experts” regarding this and the opinion is split 50/50. What is the correct method?
    Appreciate any help. Thanks
  1. Vectra c air bag issue b1000 error code
    By Justns8293 in forum Vectra C / Signum Car Chat
    Last Post: 1st November 2018, 21:47
  2. p1792-71 gearbox fault code plus alarm sensor fault codes
    By stu f in forum Vectra C / Signum Car Chat
    Last Post: 13th August 2013, 21:05
  3. airbag fault
    By veccyv6 in forum Electrical & ICE (including SatNav)
    Last Post: 28th August 2012, 16:35
  4. Dog of a Signum AIRBAG LIGHT.....No OBDII fault code?
    By Kingacx in forum Vectra C / Signum Troubleshooting
    Last Post: 25th August 2012, 10:30
  5. B1000 airbag fault - what would you do?
    By James24 in forum Electrical & ICE (including SatNav)
    Last Post: 24th January 2011, 12:51
Saab DTC B1000-C5
vauxhall vectra b1000-c5 fault code
b1000-c5 vectra
13129843 cl
vectra c b1000 fault code
b1000 fault code
b1000-c5 airbag
Vauxhall DTC B1000-C5
second hands parts opel vectra c 1.8 2003 airbag gp
Saab airbag code b1000-c5
opel vectra c airbag ecu 13118804AQ
B1000-c5 opel
vectra airbag cl
vectra c srs module code cl
AIR BAG ECU VAUXHALL 13129843 CL
vectra c airbag control unit cl code
vauxhall vectra airbag ecu 13129843 cl
ecu 13129843 cl
vectra c airbag ecu GP
vectra c airbag ecu failure
Opel DTC B1000-C5
