Thread: Rear Anti roll bar moved??
    durham
    Trim : Leather
    Default Rear Anti roll bar moved??
    Bit of advise please lads, I fitted new rear banana arms and rear drop links about 5 weeks ago cars been fine till last week when a rattle like noise started from the rear end, it's been getting on my nerves, so tonight I took the near side wheel off and noticed the drop link is touching the side of the banana arm? It wasn't when I fitted it. I looked at the other side and I can get a finger between that drop link and banana arm. So what gives ? Cars a vec c hatch. 05 plate
    Mar 2007
    Beaconsfield, Bucks
    I noticed this too on mine when I fitted them. The drop links have to go the right way around as they arent symmetrical, they have a deeper cut out which goes on the side facing the ARB. I fitted one the wrong way around and noticed when I went to do the ARB bushes. I had to remove it and flip by 180 degrees.
    durham
    Trim : Leather
    Thanks for your reply marly, I'm nearly sure I put them on like you say as I noticed the cutout but will check tonight and see thanks again.
    durham
    Trim : Leather
    Just an update on this - marly you were right I fitted the ****** wrong way! Can't believe I did that oh well you live and learn .
  1. Rear anti roll bar bush
    By pjabrid in forum Suspension, Wheels & Brakes
    Last Post: 15th December 2012, 13:14
  2. Rear anti roll bar
    By mdibb2009 in forum Engine & Drivetrain
    Last Post: 1st July 2011, 08:09
  3. rear anti roll bar....help please...
    By david.aka.judas in forum Handling & Braking
    Last Post: 20th November 2010, 13:15
  4. Anti roll links or anti roll bushers
    By beethamwest in forum Vectra C / Signum Car Chat
    Last Post: 6th May 2010, 18:46
  5. Anti Roll Bar - rear?!?
    By Leemarksmith in forum Handling & Braking
    Last Post: 25th March 2010, 17:51
vectra c remove rear anti roll bar
fitting anti roll bar bushes vectra c
removing vectra c rear arb
