Results 1 to 10 of 11
Thread: Ebay wheels fitted
    Dec 2011
    Seaham
    Default Ebay wheels fitted
    You may remember that I had put a daft £100 wine fueled bid on a set of Omega MV6 wheels. I collected them on Saturday from Keighley.
    I have fitted them straight away, whilst they really could do with a re-furb to make them perfect, they are really in pretty decent nick the way they are and actually slightly better then the ones I took off (Standard 16 inch Designs which I no longer need). I am going to run them for a while the way they are.
    They currently have 235/45/17 tyres on them, which I know is not a standard Vectra fitment, however the tyre size comparrisson calculators shows that this is an almost identical match to the 215/55/16's that were fitted.
    I am going to put a full set of new tyres on and thinking of fitting Kuhmos.
    Anyway now for the photos, I know it is high at the front and may do something with the front ride height later?
    Car from side
    Front
    Front showing how far they come out of the arches
    And from the rear, again showing how far they stick out.
    Well lads and lasses, what do you think??
    Regular Member SEANYboi's Avatar
    Dec 2012
    Bourne end,high Wycombe
    5 Post(s)
    Vehicle : Vauxhall vectra
    Trim : Sti nav
    Engine : Cdti 150
    Year : 55
    Mileage : 96000
    Think they look ok. Just needs to be lowered
    Regular Member Angel1368's Avatar
    Mar 2012
    liverpool
    34 Post(s)
    Trim : VXR
    Engine : 2.8 V6 turbo
    Mileage : 44,000
    they look ok bud very different which is what i like? do you like them as thats the main thing
    Regular Member puppet's Avatar
    East Ayrshire
    10 Post(s)
    Vehicle : Insignia 1.8 SRi
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    Think they look pretty good, and certainly a bargain for the money.
    Like you say though, it does seem to be sitting rather high, even for standard springs. Were the pictures taken before it had settled again after having it jacked up?
    Regular Member bigstu31's Avatar
    May 2012
    Southampton ish
    Vehicle : vectra
    Trim : Sri
    Engine : 1.8 vvti
    Mileage : 64000
    Like in a weird way something diff and for the price u got them at no one could grumble
    Dec 2011
    Seaham
    Thanks for the positive comments, I must admit I do like them and they are certainly different. I didnt realise they are actually Irmscher Ronal wheels.
    Yes the front photo was taken just after they were fitted, however my Veccy has ridden a little bit high after the springs were changed about a year ago!! Maybe need to get some slightly lower........
    Regular Member ThatAudioBloke's Avatar
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    Not my cup of tea personally - to me they look a bit too 'soft' against the angles of the vec. I think that's why wheels with defined spokes work well on the vec C, they complement the more angular lines on the bodywork.
    Of course, s'not my car, so if you like them then that's all that matters!!
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    The wheels look good, and were a good bargain, and different. I actually fancy solid wheels on mine, ie no gaps.
    What springs did you have changed, front and/or back?
    Your front looks about as high as mine (2008 Design HB), which is on original front springs.
    The rear springs on mine have been changed, supposedly with the correct after-market springs, but it is definitely about 30mm lower. Which is good.
    The back now feels a bit firmer, but still looks slightly higher than your car.
    But I now need to replace the front springs but not sure what ones to get.
    Dec 2011
    Seaham
    Thanks Tony.
    Mine is a standard Design model, the front springs were replaced with after market ones and always looked a bit high, maybe should have got SRI springs fitted instead. I do not want the car to ride too low as I go across some quite rough ground. But I do not like the nose up stance it has now.
    I actually have rubber donuts in the back springs for when I have the car fully loaded.
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    i do like them wheels, look good on the car too....
    Midlands Mod Shop - NFFC.
  1. Wheels and Ebay
    By mickeystitch in forum The 'Off Topic' room
    Last Post: 1st July 2011, 12:19
  2. Anyone fitted one? VX dvd headunit (ebay)
    By scotty84 in forum Electrical & ICE (including SatNav)
    Last Post: 29th June 2011, 12:28
  3. Anyone got these wheels from EBAY ?
    By soulman in forum Vectra C / Signum Car Chat
    Last Post: 12th January 2011, 15:28
  4. new ebay items fitted
    By tat2006vectra in forum Quick Photo Album
    Last Post: 16th March 2008, 13:08
