Hi all, have been busy replacing my injector seals following this guide http://myweb.tiscali.co.uk/mozzer/ho...ectorseals.pdf but have had a problem.
After turning her over by the crank to get the engine to TDC I forgot to remove the spanner from the crank pulley.... you can see where this is going lol.
Anyways my little one is like my shadow and has to be outside with me, so she was playing in the car when I had my head under the bonnet, I had the keys in the ignition to listen to the radio. The car was practically all back together, fuel lines back on, inlet manifold back on, just the turbo boost hose to reconnect when she flicked the key..... engine turned over very slightly and I heard a knock and the spanner fell off.
Thinking nothing of it I've finished putting her together and tried to fire her up, she wont startshe will run on easy start but as soon as I stop spraying it the engine stops.
I put it on o***m since the spanner light was on the clocks, and it says something about pump timing malfunction. So i took back off my rocker cover fearing the worst that the chain has snapped, but the chain still looks in tact, re-alligned engine to TDC and the scratch marks I put on the cam line up with the cam sprocket perfectly. I however can see the notch on the crank pulley to see if its jumped there.
Is it possible to the fuel pump to jump a tooth?
The cam followers look fine as does the cam
Any help appreciated.
