Results 1 to 10 of 27
Thread: Veccy 1.9cdti 150 - 3 year old issue - trying to resolve again!
    Leicestershire
    confused Veccy 1.9cdti 150 - 3 year old issue - trying to resolve again!
    Well its time to try and resolve this long term issue that no one can diagnose!
    In brief I have poor low rev performance, this seems to be worse when the engine is cold but the weather is warmer (like today 17 degree), also tickover is lumpy until the engine warms up.
    The spanner light has logged an error for over 3 years, this cannot be read by an reader (not paid to go to a dealer yet tho') and does clear itself and then comes back after typically 200 miles or less.
    I have had issues with temperature not going up but the recent cambelt / water pump / drive belt / thermostat seems to have cured this - it no runs at about 80-85 degrees.
    Another issue to raise is that whenever I have had a service or work done the car runs like a dream - great acceleration - but this last for minutes
    I am aware of the boost sensor and egr cleaning - both were done at Xmas.
    This is an annoying problem I want o finally get rid of...please help!
    Mar 2010
    Trim : Design
    Engine : 1.9 CDTi
    What code reader were you using?
    Sounds like an egr problem to me.
    Had a CDTi in last week and the car wouldnt tick over and when driving had low power.
    Fitted a new egr and car was back to normal again.
    Regular Member AntSSSS's Avatar
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Year : 2008
    Mileage : 100k
    TBH mate - you need a decent code reader and all will be revealed. So TechII or Vaux-Com.. Could be glow plug related, could be duff sensor - but until you actually plug it into a decent code reader - you will be just guessing.
    Middlesex
    Trim : SRI
    Year : 2008
    Mileage : 100k
    run the car with the egr unplugged. you will get a spanner - but see if it makes a difference on how it runs.
    Leicestershire
    I have my own card reader - not sure of the model but I have also taken it to a garage and then couldnt read it. I have a blanking plate I could fit to see if it runs better and then if so replace the egr?
    Leicestershire
    Quote Originally Posted by AntSSSS View Post
    I guess this is easier than blanking it off
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Get a dedicated vauxhall scanner on it.
    What's milage on car?
    Regular Member stevoxsi's Avatar
    Sep 2012
    Coleraine, Norn Iron.
    Vehicle : Insignia
    Trim : Sri Vx-line
    Engine : 2.0 Cdti 160
    Year : 2011
    If its stuck open unplugging it won't help. If there's no difference stick in the blank.
    Leicestershire
    Mileage is coming up for 90k bu this issues has been around for 3 years. Also I have had 2 replacment EGR valves during the life of the car.
    Does anyone know where I can get the code reader by a 'proper' reader in the LE11 or Nottingham area, is it dealer time?
    so my options are - unplug and test, then blank and test to see if any difference is made?
    Sep 2012
    Vehicle : Insignia
    Trim : Sri Vx-line
    Year : 2011
    That should rule out the egr.
  1. Vectra 1.9cdti 4th Year Service & MOT
    By keefy*2010 in forum Vectra C / Signum Car Chat
    Last Post: 3rd September 2011, 15:36
  2. Injector issue 1.9CDTI (120)
    By rec in forum Engine & Drivetrain
    Last Post: 9th March 2010, 00:12
  3. SRI 1.9CDTI 150: Power Issue
    By barkzz in forum Engine & Drivetrain
    Last Post: 7th April 2009, 19:03
  4. How much have you spent on the veccy this year?
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 21st January 2009, 12:37
