Thread: Car judders occasionally, but doesn't stall
    Regular Member TwitchyWizard's Avatar
    Mar 2013
    Vehicle : Vauxhall Vectra 1.9 CDTi (120) (Facelift)
    Engine : 1.9 CDTi (120)
    Year : 56
    Default Car judders occasionally, but doesn't stall
    I have the Vectra 1.9 (120) and it judders sometimes, its starting to do it more often.
    I use to have an Astra 1.6 8v where it juddered and if you don't keep the revs up it'll stall. (Foot on throttle at red lights for eg)
    this turned out to be the good old EGR valve where I had to get it blanked off and also tell the ECU to remove it.
    Could this be the same problem?
    Thanks for reading!
    Apr 2012
    cambridge
    Might be the start of 3rd injector problem, that's how mine started, if you unplug third injector electric plug on 3rd and either 2nd or 4th and the 3rd is brittle and more worn looking then it could be that.
    Mar 2013
    Year : 56
    Thanks for your reply.
    Is this a difficult job and how do you get to it. Expensive? If it is this would there be a fault code? What happens if i was to leave it?
    cheers
    Jan 2008
    Lincs
    Vehicle : Vectra C Hatch
    Trim : Exclusive Plus Pack
    Engine : 1.9 CDTi Z19DTH
    Year : 57
    Mileage : 100k+
    Aug 2011
    poole
    oh and p.s dont make the mistake i made the first time and take it all right off the block like a moron.... its just 3 bolts and not the 16 i took off the first time.. whats the old saying "learn by your mistakes"
    Aug 2011
    poole
    sorry i messed up the first post.. i done my own egr valve and its easy but first time i took EVERYTHING off the block DOOH
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    120's dont tend to suffer from the injector loom problem, seems to only effect the 150 engine. Could well be the EGR or the throttle body... take them off and give them a good clean, easiest and cheapest option by far.
    Mar 2013
    Year : 56
    Default :)
    Quote Originally Posted by davie2876 View Post
    Haha thanks for the advice mate but i wont be doing it myself. Will probz just leave it. If i do a pedal teick will it come up with a code assuming you can do it on a 1.9 cdti without causing damage
    Feb 2013
    South Wales
    Vehicle : Cdti
    Trim : Cdti 120 Energy
    Engine : 120
    Hi
    I have the same problem on my 120 its always under the turbo range i could be going along at 1.6k revs and its just starts spluttering but if you put the lead foot down it will fly
    Had it on opcom and the Maf was comming up so im hoping that will stop the problem once i get a new one
    Timisoara, Romania
    10 Post(s)
    Trim : Estate
    Engine : Z19DT
    Mileage : 210.000
    Hi guys,
    On the Romanian Opel (Vauxhall for UK) forum is spoken about a possible problem related to the camshaft, valves, cam followers (look like glasses). The 120 horsepower engine is known for the tendency of "rounding" of the cams. It happened to me. I replaced the camshaft but the juddering problem has not disappeared. Then I came across a service manual which is talking about the tolerancies that must exist at the intake and exhaust valves. On my car now, those tolerancies are double and even triple than normal. And that because I replaced the cam followers (I am not sure this is the correct English word for them but hopefully you get it, they look like some small glasses and the valves are punching them when the engine works) and the "pills" (they are like coins, on top of the cam followers) without measuring exactly what tolerancy should have the pills vs the valves (somewhere around 0.20 - 0.3 for intake and exaust valves), in order for the valve tolerances to be accroding to the manual.
    I am waiting now to complete the intervention and will get be back with details. What I know is that a too big or too small clearance can cause juddering, noisy motor or "un-round" engine.
    I came upon this possible issue after cleaning and afterwards replacing the EGR, the throttle body, the MAF sensor, the vacuum pump, updated the ECU software...nothing worked for me.
  1. Replies: 3
    Last Post: 5th January 2012, 19:15
  2. Vectra battery light occasionally coming on
    By Mark Curran in forum Engine & Drivetrain
    Last Post: 2nd August 2011, 17:37
  3. 1.9 CDTI 16v occasionally not starting
    By RikD in forum Engine & Drivetrain
    Last Post: 17th April 2010, 19:04
  4. Car kangaroos and judders help please...
    By lester8436 in forum Vectra C / Signum Troubleshooting
    Last Post: 16th June 2009, 12:42
  5. Car judders when accelerating recent service
    Last Post: 17th April 2009, 19:57
judder and battery light on vectra
judders but doesnt stall
