Results 1 to 10 of 20
Thread: Air conditioning - what to check ?
    Dec 2011
    Woking
    Trim : Exclusive
    Engine : 1.8vvt (Z18XER)
    Mileage : 58000
    Default Air conditioning - what to check ?
    Just tried my AC and it is not cooling. What should I look for to see where the problem is ?
    - The fuses are all ok.
    - When I press the A/C button, the light comes on but I don't here any clunk under the bonnet.
    What are the basic checks I can do ?
    Jun 2011
    Buckley Flintshire N.Wales
    Vehicle : vectra
    Trim : .....................
    Engine : ....................
    Year : .....
    If its had a leak and it has no gas it won't clunk I believe the ac pump won't work unless the system is charged,mine was the same had it pressure tested and it looked like it had been shot with a 12 bore,new condenser regassed relieved of 180 quid and its been find ever since
    Wirral
    10 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    Needs a re gas probably. Quick fit do it for 50 quid. The compressor won't turn on no matter what the light on the heater controls say if the pressure in the system is too low. They'll vacuum the system out and if it detects any leaks you can go from there.
    Dec 2011
    Woking
    Trim : Exclusive
    Mileage : 58000
    Cheers - i'll look out for a special offers etc and get it done next couple weeks.
    Dec 2011
    Woking
    Trim : Exclusive
    Mileage : 58000
    Kwikfit are doing an AC recharge for £29 if you book it on line. Got it done today - so far so good, working again.
    They just connect up this machine with a red pipe and a black pipe and leave it to get on and about 30mins later it's done !!
    Feb 2011
    Selby
    Quote Originally Posted by Dal5band View Post
    I'd like to hope they inject a fluorescent dye, bring it up to pressure then check round the pipes, dryer and condenser for leaks, as well as visually inspecting all the joints for signs of corrosion, stress or leakage too. And also setting the machine to put in the correct amount and type of oil and refrigerant. There's more to regassing an aircon system than just sucking out the old and pumping in the new...
    Dec 2011
    Seaham
    The machine recovers any remaining gas, then will complete a pressure check. If the system passes the pressure check it will be automatically re-gassed to the correct value of gas and oil etc. The machine is pre-programmed to the car it has been connected to.
    The dye will only be needed if there is a leak.
    I had mine done at Quick Fit over a year ago, it works perfectly and I have never switched it off since having it re-gassed.
    Jan 2013
    east midlands
    I can only see it for £49 on their website, do you have a link. My AC is dead, assume its just low on gas.
    Regular Member John Bishop's Avatar
    Oct 2010
    Booked mine on line back in december and was only charged £29
    Dec 2011
    Woking
    Trim : Exclusive
    Mileage : 58000
    Looks as though it's gone up to £49 today - just checked
    Must be a winter rate
  1. Wheels refurbed, Check - Car Buffed and Polished, Check! !
    By messermitch in forum Quick Photo Album
    Last Post: 18th July 2012, 23:18
  2. Air Conditioning
    By scarydeath in forum Vectra C / Signum Troubleshooting
    Last Post: 21st April 2012, 20:32
  3. air conditioning
    By marko1973 in forum Electrical & ICE (including SatNav)
    Last Post: 28th March 2011, 21:37
  4. Air conditioning
    By cbee101 in forum Vectra C / Signum Car Chat
    Last Post: 7th May 2008, 14:44
  5. Air conditioning
    By videodoctor in forum Vectra C / Signum Car Chat
    Last Post: 11th June 2007, 21:32
