Results 1 to 3 of 3
Thread: 2004 Vectra club 2.0 dti estate fault codes
    Apr 2013
    rhondda cynon taff
    Vehicle : Vectra C estate
    Trim : club
    Engine : 2.0 diesel
    Default 2004 Vectra club 2.0 dti estate fault codes
    Hi everyone,
    I wondered if any of you knowledgeable guys could point me in the right direction.
    I bought a 2004 Vectra 2.0Dti estate around 4 months ago. Lovely car and only 74000 genuine miles. Ive noticed that when going over around 3000RPM the EML light comes on and the car goes into limp mode. If I turn the car off and on the problem goes away.
    I have a fault code reader and it has read the following:
    P1105 - Manufacurer control
    P0105 - Manifold absolute pressure / Barometric pres. circuit
    P0100 - Mass or volume air flow A circuit
    P0234 - Turbocharger overboost condition
    Any pointers would be greatly appreciated.
    Thanks in advance
    Shaun.
    East Midlands
    P1105 is the boost sensor needs cleaning.
    p0100 is the maff sensor needs a clean do a search on here for more info.
    Vehicle : Insignia sport tourer 2.0 CDTi
    Trim : /Elite
    Mileage : 34900
    As above p0100 is your maf sensor
    P0105 & p1105 are your barometric pressure sensor , but if you are getting p0100 & p0105 +p1105 together then i would check your elec connections
    p0234 is your boost sensor
    in most cases all they will require is a clean , but as above you may need to check your wiring
    buy your self some carburettor cleaner in an aerosol can, readily available from all car motorfactors
    and still loving it
  1. fault codes vectra c turbo
    By davedave in forum Petrol Engine related
    Last Post: 29th June 2012, 13:22
  2. anyone no how to get the fault codes up on a vectra c
    Last Post: 17th May 2012, 20:04
  3. Vectra c Y22DTR fault codes
    By delboy2028 in forum Vectra C / Signum Car Chat
    Last Post: 24th February 2011, 00:57
  4. Vectra fault codes
    By luap2411 in forum Engine & Drivetrain
    Last Post: 23rd May 2010, 14:56
  5. 2004/04 Vectra 'C' 2.0 LS DTI Estate
    By Motorama in forum Cars for sale
    Last Post: 6th April 2006, 09:12
vectra c 2.0dti air mass meter faults www.vectra-c.com
