Results 1 to 10 of 25
Thread: Intake manifold repair kit
    Jan 2010
    Trim : 1.9 cdti
    Engine : 120
    Year : 06
    Default Intake manifold repair kit
    Just saw this on ebay. http://www.ebay.co.uk/itm/VAUXHALL-S...item1e798e1f37
    For those who have or are going this problem, this looks like a fix compared to large bill.
    Unfortunately, I have glued mine done already (Aargh). Maybe someone that has already used this can tell us whether it works.
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Hmm - interesting....
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    You must check the swirl flaps are not seized this will not cure that problem, all flaps must move freely 'except flap '3' which is the operating flap'.
    I thought the seizing of the swirls is what causes them to fail, so not sure how this can help, unless the manifold is removed and cleaned then this is fitted.
    Middlesex
    Trim : SRI
    Mileage : 100k
    Not always no... When I changed mine on my 2005 CDTI - the swirls were VERY free, it was just the up and down movement on the swirls that had caused the ball/socket joint on the bar/swirl top to wear and therefore fall off all the time.
    Of course - the bearings will still have excess play with this applied - but I guess its more secure than the plastic joints.
    Engine : 1.9 CDTi
    If they are free moving and no gunk around them this should give you a bit more life from the inlet.
    Regular Member vmb2722's Avatar
    May 2012
    Blackpool/St Mary's Bay
    19 Post(s)
    Trim : Exclusiv
    Much more fun just to change it tho!
    Middlesex
    Trim : SRI
    Mileage : 100k
    Quote Originally Posted by vmb2722 View Post
    Its a delight of a job
    Regular Member Dennisd's Avatar
    Oct 2010
    Netherlands
    Trim : Sport
    Engine : 1.9dth
    Mileage : 92000
    I have fitted the kit 123rado mentioned, it's really easy. The hardest thing is removing the plastic clips from the bar.
    Fitting only took me a couple of minutes without removing the glowplug caps. I connected and eletrical wire to the middle just to make sure the bar will stay on the "right" side.
    May 2006
    scotland
    Much more fun to glue em open. Super Glue has held mine for 10k miles and still no sign of any gunk coming out of them (which there was before gluing). Car goes like a rocket with re-map and millers double doze
    Middlesex
    Trim : SRI
    Mileage : 100k
    Quote Originally Posted by wickedwillie View Post
    I think you are right. This is £50.. Arildite is about £5...
    Bond them open - and it may also bond them down and stop the up and down movement also... Got to be the best fix really thinking about it bar a new inlet.
  1. Vecta Intake Manifold
    By dalekirkwood in forum Engine & Drivetrain
    Last Post: 30th December 2012, 22:58
  2. For Sale: Intake Manifold
    By neill in forum Parts for sale
    Last Post: 20th September 2012, 14:36
  3. Dreaded Intake Manifold
    By cooky516 in forum Vectra C / Signum Car Chat
    Last Post: 9th January 2010, 12:12
  4. Intake manifold £££
    By the-wizard in forum Vectra C / Signum Car Chat
    Last Post: 23rd February 2009, 18:31
  5. Intake Manifold Valve 1
    By Adamant in forum Engine & Drivetrain
    Last Post: 21st August 2007, 20:13
vectra c manifold repair kit
z19 engine intake manifold removal
vectra c 2008 manifold repair
