Thread: Alternator Upgrade from 105 to a higher ampage?
    Aug 2007
    North West
    Trim : SRI With a few added extras
    Engine : 1.9 CDTI 120
    Year : 06
    Default Alternator Upgrade from 105 to a higher ampage?
    I'm having alternator problems with my vec cdti 120 as detailed here:
    http://www.vectra-c.com/forum/showth...nator+cdti+120
    It currently has a 105 amp alternator, can I upgrade it to a 120 amp, for example, or will this cause electrical issues and should I just stay with 05?
    The reason I ask is that I'm looking to do some electrical mods to the car... rear electric windows, and more specifically, heated seats front and back. The windows I can't being a problem at all, but it's the heated seats, which will draw more juice. Just trying to think ahead, fed up with the electrical issues that seem to be plaguing me at the moment
    EDIT: Having read some more on the subject it looks like I can safely upgrade to a 120 amp, just got to find one that won't brak the bank, fit that and use my old one as a spare, seeing as my luck with electrical it44ms on the vec seem to suck at the moment !
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    A general rule of thumb is fit the biggest battery and alternator that you can afford. so yes.
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    I upgraded my old Vecs 105 to the 150 one or was it the 145 cant remember the amps but i know it was the highest one for my 120 CDTI as they are 3 for it 105/120/150 or 145 lol
    Full Member Z80's Avatar
    Apr 2008
    Noumea
    16 Post(s)
    Vehicle : Opel Vectra GTS
    Trim : Elegance
    Engine : 2.2 DTi 16V
    Mileage : 75 000
    Diesels are fitted with 140 A alternators. Definitely would help if intending to upgrade car audio setup with some greedy amplifiers (don't forget to upgrade the battery too !)...
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    My old Vec CDTI150 had an 80A-hr I'm sure, and it was recalled for a 100A-hr one. @tony-1977 had replaced his alternator on his old CDTI with a 120A-hr and claimed to get good results. Remember with an alternator though that upping it's capacity will have potential implications should you not be using that capacity.
    Apr 2008
    Noumea
    16 Post(s)
    Trim : Elegance
    Mileage : 75 000
    A matching battery will be enough then, and it won't harm if you're not using its full capacity after that. But yes, you'd better match at least the battery and the alternator.
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    Quote Originally Posted by Z80 View Post
    What do you mean match the battery and alternator?
    Apr 2008
    Noumea
    16 Post(s)
    Trim : Elegance
    Mileage : 75 000
    More powerful alternator = larger battery !
    For a 140 A alternator, a 75 Ah battery would be the absolute minimum, and you can use up to a 95 Ah battery, for instance, if you can manage to fit it !
    Jan 2012
    Milton keynes
    Mileage : 38100
    Ah, I see...
    Engine : 1.9 CDTi
    What a load of rubbish lol.Fit the biggest alternator you can.The battery will only draw what current it needs to recharge.Measure the current draw on a car and you will see that most of the time the battery is drawing less than 40amp's.
  1. Alternator Positive...? (Big 3 Upgrade on a 1.8)
    By silestanix in forum Electrical & ICE (including SatNav)
    Last Post: 11th November 2011, 13:37
  2. cdto 150 alternator ampage
    By coooky in forum Electrical & ICE (including SatNav)
    Last Post: 10th November 2011, 14:03
  3. 05 plate CDTi Vectra alternator ampage?
    By Tackleberry in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2011, 19:43
  4. Higher Rated Alternator
    By RobW in forum Engine & Drivetrain
    Last Post: 23rd April 2010, 17:16
  5. higher or lower ?
    By signumboy in forum Styling
    Last Post: 28th February 2008, 12:04
1.9 cdti alternator upgrade
Alternator upgrade astra
vauxhall astra alternator upgrade
astra h alternator upgrade
vectra c upgrade alternator
vectra c alternator 1.8 120 which amp
opel corsa c alternator upgrade
zafira dti upgrading alternator
zafira dti sri alternator upgrade
astra h 1.9 cdti alternator retrofit
