Thread: HELP :) Fault code P2279 - Power train - Intake air system leak
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    Default HELP :) Fault code P2279 - Power train - Intake air system leak
    Hi all,
    Driving on the M1 today, suddenly lost power and whilst driving fast (70mph) didnt notice any issues, but going from stop to any speed, it took ages, like no power at all, again ok once at speed.
    Any ideas? I have the fault code: P2279 - Power train - Intake air system leak.
    I've looked at prevous posts, but can't find anything really related to my problem.
    Thanks in advance.
    Regards.
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Check all the pipe work for splits and manifold for leaks
    On another planet
    Engine : 2.0
    Cheers dude, tried all that Cant see anything a-miss.
    Jan 2010
    Perkinsville, County Durham
    Trim : Sri nav
    Engine : Z19dth
    Sticky Egr valve letting air through when not requested?
    Regular Member carl78's Avatar
    Mar 2012
    Telford
    You could also check intercooler for leaks
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 167340
    i have couple of threads on threads check the egr solenoid
    http://www.vectra-c.com/forum/showth...ult-code-P2279
    post 8
    also post 3 below
    http://www.vectra-c.com/forum/showth...2279-grrrrrrrr
    On another planet
    Engine : 2.0
    Thanks Gents.
    The AA arrived, hit the EGR with a hammer a few times and the fault disappeared.... He kindly took the EGR valve off and cleaned it.
    All working corrctly again now.
    He did say that it was a common problem with Vectra's - LOL.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 167340
    glad to help mate
    Jan 2010
    Trim : Sri nav
    Engine : Z19dth
    Time to blank and map out.
  1. P2279 Intake Air System Leak Detected B-035
    By mattsastra in forum Engine & Drivetrain
    Last Post: 31st March 2018, 18:12
  2. P2279 Fault Code - Ait Intake Leak
    By McLovinH in forum Engine & Drivetrain
    Last Post: 20th September 2012, 17:54
  3. Fault code P2279?
    By Phil MC in forum Engine & Drivetrain
    Last Post: 8th July 2012, 19:29
  4. 1.9 CDTI fault code P2279-11
    By mozzer99 in forum Engine & Drivetrain
    Last Post: 14th June 2011, 20:13
  5. fault code p2279
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 20th November 2010, 20:14
VAUXHALL P2279-O
neo engine error at 150 km
https:www.vectra-c.comforumshowthread.php185723-HELP-)-Fault-code-P2279-Power-train-Intake-air-system-leak
Vauxhall Astra - fault code P2279
vectra c air intake leak code
vauxhall 1.9 cdti engine code P2279 only but Turbo wont work Fault
photo air leak vectra c 1.9 cdti
insignia air intake
cdti P2279: Intake Air System Leak (Powertrain Generic)
powertrain air intake system leak
P2279 insignia
opel zafira b error codes p2279 -5b
p2279
vw vikakoodi p2279
2279 OBD Trouble Code 1 result found P2279 - Generic Type Powertrain - Fuel and Air Metering and Auxiliary Emission Controls - ISOSAE Controlled Description Intake Air System Leak
fault code p2279 only when engine hot
Trouble Codes P2279: Intake Air System Leak (Powertrain Generic)
vectra c power train
insignia error codes powertrain
vectra c air intake sys air leak
zafira P2279: Intake Air System Leak (Powertrain Generic)
code erreur p2279 powertrain
powertrain vectra c
vectra c 1.9 cdti 150km error p2279 help
P2279 i cant find the problem vauxhall zafira design
