Thread: Any carpet fitters on here
    Dec 2010
    London
    6 Post(s)
    Vehicle : Hyundai Ioniq Hybrid
    Trim : Premium SE
    Engine : 1.6 with 32KW motor
    Default Any carpet fitters on here
    Like the title any carpet fitters.
    I need to pull some floorboards up but the carpets are glued.
    How hard is it to pull these up and what damage could i do to them and could i reglue when finished??
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Are they rubber backed?
    Dec 2010
    London
    6 Post(s)
    Trim : Premium SE
    I'm not sure
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    Might be worth getting a all bit by door or corner that seeing if its rubber backed.
    if its rubber backed then most likely pull the runner to pieces when you pull it up. Resulting in new carpet being needed.
    If its not then, it'll be fine to pull up adjust glue back down again.
    thats just from personal experience.
    Dec 2010
    London
    6 Post(s)
    Trim : Premium SE
    Ok cheers Critch
    Dec 2012
    Southampton
    I'd imagine it is rubber backed, hessian doesn't need glueing,
    To suggest I would minimise damage by getting a stanley blade under it to separate the glue from the floor, you will lose a bit of the backing but should retain enough to re-glue if you work slowly and carefully.
    Regular Member mccluskey119's Avatar
    gourock
    most carpets now are either hessien backed or felt backed if its glued it will be felt. i work in a carpet shop at the weekends and the only rubber carpets i sell are industrial . i dont even deal with runner backed bathroom carpets anymore . if its felt a tin of spray glue should be ok tp put back done as long its down tight as u can . failing that a fitter shouldnt charge a fortune for doing it.
    paul
  1. any carpet fitters on here?
    By chris1804 in forum The 'Off Topic' room
    Last Post: 11th September 2010, 19:54
  2. Tyre fitters !!!
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2010, 23:01
  3. any windscreen fitters...
    By Gr4eme in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2008, 21:31
  4. Anyone recommend ICE fitters in NW
    By dennis_signum in forum Electrical & ICE (including SatNav)
    Last Post: 15th May 2008, 09:50
  5. tyre fitters!
    By blr123 in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd April 2006, 23:40
carpet fitters wirral
