Results 1 to 3 of 3
Thread: Power steering lumpy
    Glossop
    Default Power steering lumpy
    I have an intermittant problem with the Power Steering going lumpy then very heavy, it comes & goes without a pattern. The fluid level is correct and there are no leaks. The electrical connections appear tight but the veh has recently had a new alternator so there has been activity in the area. Does anyone have a wiring diagram so I can check the cables are ok?
    Vec C 1.9 CDi Hatch 2006
    Dec 2011
    Seaham
    It may still be your alternator? If it is not giving out enough current, it is possible even for new or re-con alternators to fail quickly. Especially as the fault has appeared since the new alternator was fitted.
    What does the Power Steering Pump sound like?
    It should be almost silent
    However, if you can hear it when turning the steering wheel then the main bearing is nearing the end of its life; eventually it will fail, but this can take up to 2 years
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. No power & very lumpy running 1.9 cdti
    By phil147 in forum Engine & Drivetrain
    Last Post: 19th June 2013, 17:25
  3. smoke, loss of power, lumpy, cut out, help please.
    By GrannySmiff in forum Vectra C / Signum Car Chat
    Last Post: 17th April 2012, 07:06
  4. cdti running really lumpy and no power??
    By richiem in forum Engine & Drivetrain
    Last Post: 7th July 2010, 19:16
  5. Lumpy tick over and no low end power - Help
    By markluk in forum Engine & Drivetrain
    Last Post: 8th June 2009, 07:58
vectra c 1.9 lumpy steering
