Results 1 to 10 of 13
Thread: CRD2 documents
    Sunny UK
    Default CRD2 documents
    Hi
    Recently purchased above mentioned box second hand....unfortunately no docs/instructions.I have the graphs (sent by DTUK) of the maps.CAn anyone post a clear scan of everything I need to know?
    Johny
    Would it not be easier just to contact them for instructions?
    Sunny UK
    Hi Duncan
    Yep but dont fancy ringing this time of night . Fitting it shouldnt be a problem its just the settings/jumpers.If anyone has a diagram of the basic setting (map 1) that would be a start
    Johny
    Regular Member The Doc's Avatar
    'Norf Yorks.
    Basically plug it on and go matey
    The way to adjust a CRD2 is as follows....
    The long set of jumpers is to adjust the map set either plus or minus 10%. As follows.
    |30%|20%|10%|0%|-10%|-20%|-30%|
    So which ever one the jumper is on is where it is set.
    The jumpers on the left hand side in a combo of 4 determine which map you are on.
    Map 1:
    0 - 0
    0 - 0
    Map 2:
    1 - 0
    1 - 0
    Map 3:
    0 - 1
    0 - 1
    Map 4
    1 - 1
    1 - 1
    Where 1 is the connection covered by the jumper.
    Sorry clear as mud but hopefully helps!
    Not being picky Jon, but don't the jumpers just increase / decrease the voltage. Correct me if I'm wrong but there's no map stored in the box is there? It's a voltage profile isn't it?
    Quote Originally Posted by Johnytuono View Post
    Hi Duncan
    lol - righto! You're obviously keen to give it a whirl!!
    Sunny UK
    Cheers CDTI...great info
    Johny
    'Norf Yorks.
    Quote Originally Posted by AJA View Post
    Depends how you define a map really Alex.
    For example a map out of WinOLS on an Alfa 156 2.4 JTD for instance as below that is a 'map' out of the ecu. There are 48 different maps on the car which all control different parts of the car. One for fuel, injector timing, throttle response etc. etc.
    On the CRD2 as many other tuning boxes on the market the voltage profile is considered a different map as such. So profile/map I would consider the same thing really.
    If you look at a 2D map off a CRD2/Spider/CRD2 it will look like a fuel map as shown below off the ECU.
    All a map is, is relating a point from RPM against throttle position etc. The jumpers just add 10% or decrease 10% against the map. So say at 3000rpm at full throttle on map 1 at 10% is giving voltage 5v, if you increase it 10% it will follow the same map shape but give voltage 5.5v. If you see what I mean.
    'Norf Yorks.
    Johny
    Anytime mate
    Sunny UK
    As a matter of interest what is the different bhp/torque of all 4 maps? I might be mis-reading this CDTI but by altering the voltage jumpers (eg increasing 10%) would that mean the peak torque is lower down the rev range? Or have I got it all wrong?
    Ta
    Johny
  1. difference between a DTUK CRD2 (09) & CRD2 Multi-Map®?
    By Beckman in forum Diesel Engine related
    Last Post: 10th December 2010, 22:49
  2. Member needs Documents.
    By Vectra_C_Chris in forum West Midlands
    Last Post: 2nd July 2010, 10:33
  3. Vectra-C, Documents Booklet- Free copy!!!
    By mushy2007 in forum General Chat
    Last Post: 27th April 2008, 21:24
  4. Replacement manuals and documents?
    By SteveBray in forum Vectra C / Signum Car Chat
    Last Post: 14th December 2006, 10:39
