Thread: Sidelights LED Workaround
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Default Sidelights LED Workaround
    Ok, so we're all well aware of the problems that arise when fitting LED equivalents as alternatives to standard incandescent bulbs in the sidelights. It doesn't matter what the claims, they will always pulse with the lamp check system and throw up random bulb failure warnings.
    The pulsing I can live with as it's almost invisible in normal daylight and I've had them pass MoT testing like that anyway.
    So, getting to the annoying problem of random failure warnings:
    A few weeks back I got hold of a couple of 'in-line resistor fitted' lamp holders... from what I was told, specifically desgined to deal with the LED problem. Needless to say I was offered them as they proved to make no difference at all.
    The approach I have taken however, is to cut away the two bulb holders and 'soft wire' them to the existing sidelight wiring (for the moment), thus giving me 4 sidelights - 1 LED and 1 W5W per side. The redundant W5W units being tape protected and tucked away, but providing the required resistance to keep the lamp check system happy.
    So far, so good... all is working well, no warnings, nice bright white LED sidies to match the HIDs.
    Assuming all remains well I may just sort out a nice little How2 (with pics) sometime soon
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    I did this with my old vectra c but with the GSI i just got a spare set of side light bulb holders and wired them to the fuse box so they came on with the ignition this way get no errors or flickering
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    I soldered in resistors on parallel too bulb an I never get bulb warning up
    55ohm 5 watt resistors (22&33 ohm soldered together)
    or a 47 ohm 7 watt resistor also works
    Regular Member ollie1002's Avatar
    Apr 2012
    northants
    If I fit resistors inline to my sidelights will this stop the pulsing when they are off?
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Nope
    Hanging Heaton
    35 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    I did this back in the day too, but powered from the dash feed (fob/lock activated), my how 2 is flying about somewhere... Also did my fog light LEDs at the same time
  1. new sidelights
    By tiimi in forum Styling
    Last Post: 6th January 2013, 17:31
  2. EGR workaround..
    By tosh23 in forum Vectra C / Signum Car Chat
    Last Post: 4th June 2011, 04:17
  3. Sidelights
    By st2malo in forum Electrical & ICE (including SatNav)
    Last Post: 1st January 2011, 16:40
  4. help with sidelights please
    By carlsondavid33 in forum Styling
    Last Post: 6th November 2010, 21:26
  5. LED sidelights
    By Guyver1 in forum Vectra C / Signum Car Chat
    Last Post: 24th February 2010, 20:32
