Results 1 to 10 of 11
Thread: Smoke from exhaust after injector washer replaced..until disconnect sensor..
    Oct 2012
    Perth
    Default Smoke from exhaust after injector washer replaced..until disconnect sensor..
    Hi Guys,
    Today I replaced the injector washer on my sri 1.9 cdti 150 vectra...it was no1 left hand side coil.
    I got it all connected back and thankfully no ****ing out anymore but I am now getting black smoke from exhaust and its feels a bit rough and shaky to drive...when I have the car running if I disconnect injector 1 the smoke stops...
    Does this mine the injector I changed is now screwed ? there was no black smoke before I changed just ****ing out carbon etc from the injector ???
    Dec 2011
    Seaham
    Did you re-cut the injector seat? Or at least clean all the carbon etc off it?
    It is possible that the new seal is not sealing properly.
    Oct 2012
    Perth
    I scraped the carbon the best I could I assumed it was ok as it is not hissing and I am not getting any bubbles or spray...
    Dec 2011
    Seaham
    Sure a diesel expert will come along soon and help.
    Yu might need to bump the thread later on.
    Oct 2012
    Perth
    Cool thanks for your input
    Dec 2011
    Seaham
    Have you checked that all the connectors are back on properly? After that Im stuck sorry
    Oct 2012
    Perth
    Yeah they are all back on just seems weird when I pull the sensor from the injector I fixed the black smoke stops ?
    Oct 2012
    Perth
    Ok so after reading up I have realised that the copper washers have different sides 1 side is a very slight rounded edge and the other is completely flat... I did not know this so I have a few left over so will head back out first thing tomoz and check..
    Also when I took the injector out I tried to find the old washer but could not see or grab it so I decided there wasnt one in there and stuck the new 1 in so there maybe 2 washers in and if the one I put in is the wrong way it means 2 round edges are together...
    Is there a chance there was not a washer in or did I give up too easy ??
    Dec 2011
    Seaham
    I would b surprised if there had not been a seal in there, sounds like you havent actually removed the old seal?
    Engine : 1.9 CDTi
    As said above.
    Sounds like you have 2 washers fitted and the injector is to far in the head and not igniting the fuel fully.
  1. Injector Washer ?
    By darrenswebdesigns in forum Vectra C / Signum Troubleshooting
    Last Post: 13th April 2013, 08:02
  2. Injector Copper Washer Question?
    By Leemarksmith in forum Engine & Drivetrain
    Last Post: 28th March 2013, 18:15
  3. 1.9 injector washer problem
    By Derv-head in forum Engine & Drivetrain
    Last Post: 14th January 2013, 13:47
  4. Replaced n/s front ABS sensor
    By llanddewi in forum Suspension, Wheels & Brakes
    Last Post: 11th October 2010, 16:31
  5. To those that have replaced Injector plug # 3...
    By Dan_BlackSRi in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2009, 18:52
