Thread: Alternator/Fuse???
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Default Alternator/Fuse???
    Is there any kind of fuse for the charging/alternator system?(vec cdti 150), car has or seems to have stopped charging, red battery light comes on now & again but goes out for a while when engine is re-started, no change in volts at battery when engine speed is raised, its only done 60k & is outside of the faulty batch numbers as its from a 07/57 rg.
    South east
    Any Vec-C is prone to a failed alternator, not just the ones within the production range you mention; that's why there are so many threads about them.
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Check output at back of alternator
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Quote Originally Posted by Critch View Post
    Thanks have u done it on this alternator b4?, its the 2 connector one i think.
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    Check a the big terminal if getting charge their but not at batt you have a problem in the leads
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    I have checked at the batt & now at the alt (big red wire & earthed to engine), Both the same voltage with no change when engine running so i guess its shot AGAIN!, Ive took it off & it just reminds me how awkward it was the last couple of times, Not replacing it with another crappy denso.
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    Sounds like alt is shot mate try a refurb place rather than replacemt unit.
    one of lads in work got his alt on his v50 refurbed for 45 quid
  1. alternator fuse??
    By ADAM123 in forum Electrical & ICE (including SatNav)
    Last Post: 19th February 2012, 11:54
  2. ignition live fuse in under bonnet fuse box
    By TimTay in forum Electrical & ICE (including SatNav)
    Last Post: 13th August 2011, 15:19
  3. What does fuse 26 do in the engine compartment fuse box?
    By rich05uk in forum Vectra C / Signum Troubleshooting
    Last Post: 8th January 2011, 22:02
  4. Which fuse?
    By Adam in forum Vectra C / Signum Car Chat
    Last Post: 16th December 2007, 09:41
  5. car kit fuse
    By daveg8843 in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2007, 22:58
vectra c alternator fuse
corsa c alternator fuse
corsa c alternator fuse location
Opel corsa alternator fuse
zafira alternator fuse
vauxhall vectra alternator fuse
opel astra- G 1 alternator fuse locatio
vectra c alternator not charging
astra cdti alternator fuse location
2004 opel astra alternator fuse locationdo I have a fuse for my alternator vectra vauxhall vectra 2002 alternaTor fusealternator fuse Opel corsa cOpel 1.9 cdti fuse for alternatorvectra alternator fusecorsa c does the alternator have a fuse2004 astra 1.7 diesel. alternator fusecorsa d alternator fuseastra alternator fusevouxall alternator fusesalternator fuse link on opel astra fzafira alternator fuealternator fuse corsa 1.7 dieselcorsa c 1.7d alternator fusevectra c charging fuse
