Thread: rear caliper problem. ..
    Feb 2013
    Barnsley
    Trim : sxi
    Engine : 1910 cdti diesal
    Default rear caliper problem. ..
    My cars been off road for past 8 wks and since fitting a new intake manifold plus egr and many many pipes n other stuff stripped off, since putting bk together ive hsd countless problems e.g. tonights episode LR PS caliper..
    I was trying to push bk in with pliers and twisting but it wasn't budging, tried loosing bleed nipple that weren't budgingand for some unknown stupid reason I turned the piston 1 turn anticlockwise.. Dont know why av done it but its not cone out of the rubber sleeve I.e the piston..
    scotland
    1 turn is nothing mate , its on a fine thread so will take a few to pop it out , best get a rewind tool to do it .... its a cantor with one :-)
    crook
    rear calipers can be hard to get piston back in, even with the correct tool
    Are you saying you have popped the piston out ?
    Feb 2013
    Barnsley
    Trim : sxi
    It just sticks at the same spot but a will av to buy a tool tomorrow, forgot to mention that when I turned it wrong way it moved outwards about 10mm sorry hope av not ******ed it nar lol..
    crook
    you wont have donald ducked it
    at worst if piston had popped out,its not a hard job to put back in
    Unless you have correct pressure on piston it will not go back in
    hull
    I used long nosed pliers to wind mine back in, but you need to put ALOT of pressure on the piston while turning it clockwise. I too unwound mine fully with no problems so i'm sure yours will be ok.
    Feb 2013
    Barnsley
    Trim : sxi
    Thanks all will give it a try in morning..
    scotland
    Quote Originally Posted by jodiexii View Post
    .contradiction ????
    scotland
    crook
    Quote Originally Posted by gsxrster View Post
    .contradiction ????
    Hard to wind back in,without correct tool
    If piston has popped out,easy to get back in..........contradiction ??? how ??
  1. Caliper problem
    By dawn brown in forum Suspension, Wheels & Brakes
    Last Post: 28th July 2013, 22:14
  2. New caliper now handbrake problem
    By roverjay in forum Suspension, Wheels & Brakes
    Last Post: 27th January 2013, 19:17
  3. rear caliper
    By roverjay in forum Engine & Drivetrain
    Last Post: 5th January 2013, 17:20
  4. Rear brake caliper problem
    By siadwel in forum Suspension, Wheels & Brakes
    Last Post: 19th July 2012, 16:37
  5. can any1 help caliper problem
    By callum in forum Vectra C / Signum Car Chat
    Last Post: 6th September 2010, 19:10
