Results 1 to 2 of 2
Thread: Battery drain
    Regular Member bow123's Avatar
    Aug 2011
    Castledawson
    Vehicle : Vauxhall Vectra
    Trim : SRI
    Engine : 2.2 DTI 16V
    Default Battery drain
    03 vectra 2.2dti draining the battery i replaced the battery a year ago in my car as a thought the battery had lay down only to find the new battery running down also so 6 months ago got the battery replaced but problem still draining the battery have checked for charging 12.3volts with car not running 14.8volts with car running so i take it should be charging ok replaced the alternator just in case it may be draining also removed the lights from glove box and from the boot but still draining battery i was out in the car all yesterday evening and wasnt home till 11 oclock lastnight and at 9 oclock this morning not even as much as a dash light battery completely drained
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    You need to set you multimeter to amps in series with baTtery
    and pull each fuse until drain goes.
    once you've found that you then need to trace circuit to see what's causing the draw
  1. Battery Drain
    By Alistair123 in forum Electrical & ICE (including SatNav)
    Last Post: 27th October 2012, 14:11
  2. Battery Drain
    By Gabonz1 in forum Vectra C / Signum Car Chat
    Last Post: 24th February 2012, 22:16
  3. 19 amp battery drain
    By jimbobling in forum Electrical & ICE (including SatNav)
    Last Post: 7th March 2011, 19:55
  4. CD 70 Battery Drain
    By davey9dollars in forum Electrical & ICE (including SatNav)
    Last Post: 28th March 2010, 22:05
  5. Battery drain
    By daveg8843 in forum Electrical & ICE (including SatNav)
    Last Post: 24th October 2007, 22:04
2.2 vectra battery drain problem
vectra 2.2 dti draining battery
vectra c battery drain
