Results 1 to 3 of 3
Thread: HELP car not starting, no communication with ECM
    Oct 2012
    Scotland
    Default HELP car not starting, no communication with ECM
    Hi guys, im in need of some help. The TC/ABS light came on in the car last night. I though i would check the fuses so started with the ones in the passenger side dash area. I only checked the ones i thought might be related to the problem. I also checked the ones beside the battery related to TC/ABS. When i went back into the car, i noticed the 'check engine' light did NOT apper on the dash when i turned ingintion on, where before it did for a few secs and went off. Now the car will not start, just like a clicking sound when turn to turn over. Plugged in my mates 'Op-Com' and its saying there is no communication with Engine Control Module? Any ideas and cures to this problem? I have just disconnected the battery and going to leave for a few hours to see if it will clear itself? Cheers
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    5 Post(s)
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    im having the same problem but mine only does this when its cold(below about 3 degrees)
    Try unplugging the ABS plug and check for dirty or corroded pins(its the large black connector directly behind the ABS pump) this can cause the problem sometimes.
    Also get somebody to turn the key while ur under the bonnet and see if the clicking is comming from any of the relay's in the fuse box under the bonnet next to the battery
    Ive never found the cause of mine
    Regular Member dartraxx's Avatar
    Jan 2013
    gwynedd
    Vehicle : 1.9cdti sri xp2 nav
    Trim : xp2 vxr styling
    Mileage : 68K
    Have you checked the wiring harness plug thats connected to the abs/tc, unplug it and check for any damp dirt or oxidation in the plug or abs\tc unit, apply some elec fast drying solvent, or wd40 to drive out moisture. Hope this helps pal?
  1. Tech2 no Communication with Vehicle
    By any-mgzt in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd April 2013, 09:31
  2. ODB2 communication error
    By wayne1000 in forum Vectra C / Signum Troubleshooting
    Last Post: 12th January 2012, 16:33
  3. No Can Bus Communication with Yaw Rate Sensor
    By lee632 in forum Vectra C / Signum Troubleshooting
    Last Post: 6th July 2011, 22:45
  4. U2105 No communication with ECM
    By crash112211 in forum Engine & Drivetrain
    Last Post: 18th July 2008, 14:56
can-bus no communication with ecm
vectra c z18xer no communication with ecm
z20net no communication with ecm
opcom vectra no comunication dash
i use op com my vectra c is not communicating with the ECM site:www.vectra-c.com
