Thread: Engine Rebuild
    Aug 2010
    London
    Default Engine Rebuild
    Is it easy to do an engine rebuild. Has anyone ever done it and has any guides etx i can follow to change valves and piston rings?.
    Iv never done it before but think i could maybe do it no problem. Im burning oil so think its time to rebuild rings valves and maybe other we bits and bobs .
    An guides or advice would be great
    Regular Member vmb2722's Avatar
    May 2012
    Blackpool/St Mary's Bay
    19 Post(s)
    Trim : Exclusiv
    Engine : 1.9 CDTi 150
    Get the proper piston ring compression tool, otherwise it's easy to damage them, and take your time, it's quicker to double check than it is to strip it down again after forgetting something!
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Depends on what you class as easy mate along with your level of experience.
    its not hard how ever changing piston rings involves stripping practically the whole engine.
    you will need a dti gauage to measure the bore wear to ensure you get the correct size rings too
    Aug 2010
    London
    thanks for reply's,
    problem I am facing is, iv not change the timing belt before and that might be hard enough to get off. if that was easy to do then its a case of removing screws to get in. for the belt do you just remove the air filter housing, fan belt and then upper case. once done remove very bottom large gear for fan belt. then remove bottom case and undo the tensioner for main belt all from under the car or on top, which is easyer. no need to remove wheel arch is there? how do yous support the engine also?
    May 2012
    19 Post(s)
    Trim : Exclusiv
    Support the engine with a jack from underneath so ill need to remove the splashguard and the wheel arch liner to get in easier to take stuff off
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    You'll need to support engine as engine mount needs to come off.
    make sure you set no1 cyl up tdc (timing marks)
    use paint pen/ tip ex aswel for bit of extra safety when building back up.
    once you've got that off you're looking at head off. Sump off.
    then big end caps off an tap pistons out.
    You will then need to inspect for scoring, cracking etc an measure the wear.
    a Haynes manual may make things but long winded sonetimes
    but in this instance where you're thinking along the tight lines but a bit unsure it maybe worth the investment
    Aug 2010
    London
    Iv got the manual, its great peace of information that book is. just seams complicated enough to get the belts off in the book. are you sre you deffinitly have to remove the wheel arch to do it, iv seen videos where the person has not. Also why you removed the sump, is it necessary to get the pistons out or what?
    Thanks for help guys keep it coming
    May 2012
    19 Post(s)
    Trim : Exclusiv
    The pistons are attached the the crankshaft which sits in the sump, the only way to remove the pistons is to detatch them from the crankshaft, so yes is is necessary to remove the sump!
    Regular Member ftm100's Avatar
    South Shields seagull sh*t town
    To be honest if your asking how to do things like this its beyond you no disrespect
    Jan 2012
    Dublin
    in the nicest possible way id recommend you dont touch your engine and leave it to a pro. Doesnt sound like you know much about engines, you'll only end up paying a mechanic a rediculous amount of money to bail you out if you start taking things apart. A belt should only be done by a diy mechanic who knows what theyre doing, a complete rebuild is beyond most folks, serious amount of stripping involved and some engineering know how
  1. Smoking engine after rebuild
    By G4GAV in forum Engine & Drivetrain
    Last Post: 24th June 2012, 23:25
  2. Cdti 120 engine rebuild?
    By smiley-sri in forum Engine & Drivetrain
    Last Post: 18th February 2012, 12:53
  3. VW engine rebuild kit
    By Hummelshøj in forum Non Vectra C/Signum Album
    Last Post: 14th November 2011, 15:51
  4. Engine rebuild and now in limp mode
    By jon1.9cdti in forum Engine & Drivetrain
    Last Post: 4th August 2010, 01:10
  5. my engine rebuild (not vectra but still vauxhall)
    By sbd16v in forum Petrol Engine related
    Last Post: 1st May 2008, 11:48
