Thread: Brake Pads
    Regular Member rmg1's Avatar
    Limavady, N.I
    Vehicle : Vectra C Sri V6 CDTi
    Engine : 3.0 V6 CDTi Z30DT
    Mileage : 121000
    Default Brake Pads
    I need a set of rear brake pads for my facelift v6 cdti vectra and was looking through ebay so was wondering if there is a difference between the prefacelift and facelift pads and if someone could point me in the right direction as to which ones I need.
    Regular Member tgbo's Avatar
    Nov 2010
    stirling
    Pmsl I was on the phone to arnold shark for the same thing today got quoted trade prices of £60+vat for rear discs and pads also front for the same price, beware of some disc on eBay I had a set on my astra with mintex pads the disc warped in no time really poor quality
    must admit thou the parts man was quite sure abut the right sizes
    Nov 2010
    stirling
    So can anyone help us guys with part no's please or confirmation of disc sizes for me too ;-)
    Quote Originally Posted by tgbo View Post
    What sizes did you or the Parts Department person quote?
    The front is 314mm vented and the rear is 292mm solid
    The Parts Department person at Pollokshaws Road wasn't convinced the prices were right when I asked for a quote, but came back and confirmed they were correct
    Price is full retail, no discount
    Front Pad : 93198813 £72.36
    Front Kit : 93186299 £81.46
    Rear Pad : 93192623 £57.28
    Rear Kit : 93186301 £80.46
    Regular Member Sebastian's Avatar
    Electric Heated Recaro Leather
    39 Post(s)
    Engine : 1.9 DTH
    Rear 292 vented mate....
    Apologies, should read both vented
    However when entering my vehicle on TIS the sizes for a 1.9 CDTI come up!
    I suspect this is the issue you encountered
    The same happened when I ordered the parts for my local garage
    I took one look at them and advised them that although I had provided the correct part numbers they had clearly asked for "Front Pad and Disc Kit for a diesel Vectra", woops
    Nov 2010
    stirling
    I took one look at them and advised them that although I had provided the correct part numbers they had clearly asked for "Front Pad and Disc Kit for a diesel Vectra", woops[/QUOTE]
    thanks for the help guys,
    yip their telling me it 285mm fronts and 278mm rear and am not sure their right
    If it is a V6 CDTI, then it is definitely 314mm front and 292mm rear
    It's actually easier to go into the Parts Department and ask for them by size rather than the part number!
    As above, I had the same issue with the first few brake renewals, the Parts Department kept supplying the smaller size and the Service Department kept sending them back
    After the second change I made the Service Department check the correct parts were ordered first
    Then the same issue occured with some other parts
    However, there was never any issue with the wrong parts during servicing (oil filter)
    It's almost as if the V6 CDTI is not on TIS and is specified as a 1.9 CDTI, unless it is an actual engine component
    Nov 2010
    stirling
    yip defo 3.0 v6 cdti 55reg facelift model, now ave got to look forward to calling them to order the drive belt an service kit aswell saying that i have the old invoice from the last time and a reckon the drive belt number shouldn't be to hard for them
    13 Post(s)
    There's a chart in the troubleshooting section
    http://www.vectra-c.com/forum/showth...mparison-Chart
  1. Brake Pads
    By keith1983 in forum Handling & Braking
    Last Post: 8th March 2012, 21:27
  2. What brake pads for 2.8 V6 Signum??? 314mm brake discs
    By luke4487 in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2010, 23:21
  3. New Brake pads
    By Ben999 in forum Handling & Braking
    Last Post: 15th April 2009, 21:14
  4. Brake Pads - Which are best?
    By robzc in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2007, 16:17
  5. Brake Pads
    By johnmac in forum Handling & Braking
    Last Post: 22nd November 2006, 23:52
