Thread: vectra c 1.8 z18xe rough idle and cant hold revs, any ideas before i scrap it?
    Feb 2013
    Northants
    Vehicle : Vectra c
    Trim : Ls
    Engine : 1.8
    Year : 52
    Default vectra c 1.8 z18xe rough idle and cant hold revs, any ideas before i scrap it?
    hello again, my car ran fine for 2 months then one day I started it up and it was dog rough sounded like it was running on 2, but after 10 seconds it corrected itself and was fine. this started happening a bit more often over a few weeks but would always correct itself or I turn it off and restart it and it would be ok sometimes. it went for mot and failed on lambda 1.11, garage said it was sensor so I bought a new bosch one and went for re test it failed on lambda 1.08, I put the old lambda back in and got a refund on the new one. I then changed the maf with a second hand one which I was assured was working with same part number and cleaned out the throttle body, the car was now a lot worse and was rough idle all the time? I tried a new maf and it was the same, since then I have replaced the spark plugs, coil pack, egr valve, cam sensor, throttle body, fuel filter, checked for air leaks, removed inlet actuator and purge valve - tested ok, cleaned all air pipes, ran injector cleaner through it, flushed and replaced oil and filter, tested all engine wiring loom, cleaned all earths, took ecu apart and tested all connections. if I turn off each injector in turn it sounds worse. looking at it on obd on idle the timing advance is constantly shooting from 0 to 18 when I rev it it goes to 0 . the stft is 14 but if I rev it it also drops to 0 . I thought about cat but there is a lot of pressure at exhaust rear. it drives smooth and quick but sometimes it hold the revs on gear change, and if I dip the clutch and stop it will also hold the revs at say 4k! if I change down it will jerk and then I can use the engine to lower the revs? the car has done 137k miles, could it be a sticking valve? should I run kerosene through it? im running out of ideas now so any help really appreciated before I have to scrap it which I cant really afford to do as im between jobs at the mo. barks
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    Have you changed the crank sensor if the car doesn't know where it's firing it won't run and throws up a mil light
    Feb 2013
    Northants
    Vehicle : Vectra c
    Trim : Ls
    Engine : 1.8
    Year : 52
    hi, I bought one but it fell apart in my hands, I hooked mine up to a miltimeter on continuity and when I put a big spanner to it then away again I get what seams to be a correct reading. theres no codes though? maybe I should just get one. thanks
    Mar 2011
    llandrindod wells
    When mine failed it went into limp home mode would only rev to 4 k ish
    Feb 2013
    Northants
    Vehicle : Vectra c
    Trim : Ls
    Engine : 1.8
    Year : 52
    it drives great can red line it, smooth and quick but wont idle properly and cant hold the revs at a certain value, if I blip it it goes to 1200 revs and is smooth then drops to 700 ish and goes lumpy again as the stft increases and the timing advance starts to flicker from 0 - 18 again? its very weird. if I unplug the maf it will stall, and if I rev to 3k and release the accelerator it will drop to 1k then rev to 2k hold it for a bit then drop back to idle?
    Feb 2013
    Northants
    Vehicle : Vectra c
    Trim : Ls
    Engine : 1.8
    Year : 52
    hi, anyone know where the crack case breather is located? im going to check its not blocked and the fuel pressure is ok. thanks
    Feb 2013
    Northants
    Vehicle : Vectra c
    Trim : Ls
    Engine : 1.8
    Year : 52
    if I unplug the crank sensor when car is idling then it stalls, if I unplug the maf it goes to stall then picks up but is still rough, I have good fuel pressure, ive also just checked the fuel tank breather and its fine. if I unplug either lambda no change, its looking like ecu idle map corruption? internal engine mechanical fault? bad injector? or cat?
    Feb 2013
    Northants
    Vehicle : Vectra c
    Trim : Ls
    Engine : 1.8
    Year : 52
    can anyone tell me where the knock sensor is please?
  1. vectra gsi running rough misfires high idle
    By shaunft in forum Engine & Drivetrain
    Last Post: 9th August 2012, 23:03
  2. Rough Idle and cut out - Watch Video Any ideas?
    By halster78 in forum Engine & Drivetrain
    Last Post: 23rd May 2012, 15:56
  3. Rough Idle and Low down revs
    By lofty in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2011, 22:29
  4. VECTRA SRI CDTi 150 1.9 ROUGH IDLE
    By nafmughal in forum Vectra C / Signum Troubleshooting
    Last Post: 15th January 2010, 23:23
  5. 03 vectra 1.8 emissions light and rough idle
    By likeit40 in forum Vectra C / Signum Car Chat
    Last Post: 19th December 2009, 02:41
vectra c 1.8 rough idle
lumpy tickover on vectra 1.8
vectra c 1.8 running rough
vectra c rough idle
vauxhall vectra not holding revsz18xer vvt bad idlevectra car not holding idleswapped z18xer to z18xe and doesnt want to revz18xe misfire stallingvauxhall vectra 1.8 irratic idlez18xe ruff idle06 vauxhall vectra sri 1.8 rough idle vectra c 1.8 no idle2006 vauxhall vectra c 1.8 vvt keeps nearly stalling at low revs1.8 vauxhall rough idlevuxhaull vectra petrol running roughvauxhall zafira 1.8 rough idlevecta revs wont holedvectra c 1.8 petrol runs but wont rev upcant rev car on idlevectra c 1.8 cat blocked z18xe revs up and downz18xe purge valvez18xe poor idle cutting outup and down idle z18xe
