Results 1 to 10 of 25
Thread: Suck water out of garage pit hole
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Default Suck water out of garage pit hole
    Any one know the best method "cost free" of draining out the water muck of the garage pit hole as theres a foot of water in there. Wanted to drain it out for father in law while he's away on holiday.
    Got to be without machines, basic usage of DIY and household things is an idea... But what?
    Regular Member d_ghedia's Avatar
    Oct 2007
    Berkshire
    Vehicle : Vauxhall Signum
    Engine : 1.9 CDTI 150. Manual
    You need a pump... that the only way to to do it.
    Anyone you know that has a fish pond pump... even an aquarium pump may do it.
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    Pump deffo if you were near I have one you could borrow failing that bucket n rope lol
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Any pictures? That's nice of you to do tht for your father in law, I wonder if he will let you use it?
    Jun 2011
    brum
    As mentioned, you need something to pull the water up with, the only two "automated" methods either require the use of some sort of pump, or gravity. Unless your on the top of a hill with a very long hose pipe, gravity won't help you out so your left with the latter idea of a pump.
    Failing that of course you do it manually using whatever bucket, saucepan, teaspoon you can find
    Regular Member keith1983's Avatar
    Sheffield / Spalding
    Vehicle : Vectra 1.8 SRi
    Engine : Z18XE
    Can you make a drain in the bottom of the pit so it has somewhere lower to drain to? Depending on the water table in your area this could also act as a route in for water though!
    Regular Member puppet's Avatar
    East Ayrshire
    10 Post(s)
    Vehicle : Insignia 1.8 SRi
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    Could you not manage to lay your hands on the pump out an old washing machine or something? Pump, length of pipe or two, and hook it up to some power and it would possibly work. Just a thought.
    Regular Member ScotsDragon's Avatar
    Aug 2009
    Lost in Time and Space...
    Trim : SRI
    Mileage : 50000
    HSS HIRE submersible pumps are half price hire so that saves money albeit not free but cheap....
    Feb 2011
    Selby
    Is this a standard sized inspection pit? ie about 2m x 1m x 1m. And it's less than 30cm deep in water?
    If so, by the time you've posted on here and read replies, you could have drained it using a bucket. When you get down to the last bit that you can't do with a bucket, get your wellies on and use a smaller pot to fill the bucket, then finally soak up the last bits with rags and wring them out. You could hire or buy a submersible pump, but for the sake of such a small volume of water, you might as well just use a bucket.
    Engine : Z18XE
  1. My Car was in Garage for Timing Belt and Water Pump Change
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2013, 22:31
  2. pin hole water leak in engine block !!!
    By bradie1974 in forum Engine & Drivetrain
    Last Post: 22nd September 2011, 18:56
  3. Replies: 14
    Last Post: 10th October 2009, 10:10
  4. Now this would suck..
    By AndrewTi in forum General Chat
    Last Post: 27th October 2008, 22:49
  5. Ford's Suck!!!
    By mucklestone in forum Vectra C / Signum Car Chat
    Last Post: 24th February 2008, 19:48
how to suck water out of hole
