Thread: Airbag Light
    Regular Member Dane-10's Avatar
    Feb 2012
    Sheffield
    Default Airbag Light
    Had my airbag light on now for a couple of months, and really need to get around to sorting it.
    I have checked all sensors, Though before xmas, had a issue where had to have come cables replaced/repairs though none looked like air bag.
    Any one know of any one/anywhere in or around Sheffield that can read the airbag fault? So i can then find out where to go from here.
    I have a sneeky feeling it just needs a reset, but id like to know if there is some sort of fault there.
    there cars are none stop problems! haha
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Have you checked the connections under the front seats?
    Regular Member any-mgzt's Avatar
    cheshire
    21 Post(s)
    Trim : basic
    Engine : Z19DT
    First off get some good quality contact cleaner, Toolstation sell a reasonable one at a good price, can't rember how much.
    Clean the connectors under the seats, first disconnect battery and wait 5 minutes for the system to discharge. Remove connectors and give a good spray of both halves with cleaner, refit connectors. Push both front seats all the way back and locate a second connector which is attached to the seat frame at the front edge, do the same cleaning process on these. Reconnect the battery, check if Airbag light still stays on.
    I spent months trying to solve a fault, on mine, found a recall notice from GM in the States which replaced the connectors mounted on the seat frames, no such recall in Europe. I found the connectors on mine cleaned and now no light on. I had previously cleaned the connectors that are obvious if you look under the seats and had no joy at all, but on seeing the US recall notice and finding the other connectors problem solved.
    The connector is at the top left of the photo.
    Feb 2012
    Sheffield
    It is not the front seats, that is the first port of call with any airbag light for me, Battery has been off for over 30 mins 3 times now to have other work done, So that is making no difference.
    I need the codes reading to find out where the fault is... IF there is a fault, It may just need a reset.
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    need to sort a minin meet at yours dane then we can sort it for ya
    Feb 2012
    Sheffield
    haha, something could always be arranged probably! Mini meet + Missus sunday roast special lol
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    chips with mine please or kebab lmao
    Feb 2012
    Sheffield
    Quote Originally Posted by paulvectrac View Post
    Even better! As then she isnt cooking, Might be safer!
  1. Airbag light
    By Sharpy28 in forum Electrical & ICE (including SatNav)
    Last Post: 12th June 2012, 22:26
  2. AIRBAG light .. is thier a fuse the the Airbag ecu ?
    Last Post: 10th September 2011, 13:21
  3. Airbag Light
    By rocket999 in forum Electrical & ICE (including SatNav)
    Last Post: 18th August 2011, 16:22
  4. Airbag Light
    Last Post: 30th July 2011, 21:46
  5. AirBag light
    Last Post: 9th May 2011, 18:28
