Thanks Thanks:  1
Thread: Z19dt diesel turbo removal guide?
    norwich
    Vehicle : vectra c
    Trim : sri
    Engine : 1.8
    Default Z19dt diesel turbo removal guide?
    Hi all just wondering if I can find a guide to remove turbo from my 2006 diesel 120 z19dt? And would a turbo from a y20dth fit? Many thanks.
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    take the front of the car off lol its easyer although @nutron can do it with out and no it wont fit
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    My how 2 should help. Same principle of getting into there. http://www.vectra-c.com/forum/showth...on-1-9cdti-150
    You need like for like turbo or uprated turbo for the right engine code.
    1- layout got to be the same,
    2- cant get other turbo from other different engine code as input and output will not work,
    Whoever or however gave u the expression that it could??
    South Central England
    18 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    The manifolds are different because you only have four large exhaust ports rather than eight smaller ones. You could swap the core from one manifold to the other. Doing it without removing anything actually takes longer and you really need a ramp or it is a pig of a job.
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    I changed @CH-VECTRA-ELITE only the other weekend.
    TBH its really not worth the hassle of doing it with the RAD pack still in place. Remove the bumper, crash bar and Rad pack and as @nutron says - its actually quicker.
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Just for fun here's the official way to do it.
    Remove
    1. Open bonnet
    2. Disconnect battery.
    3. Detach engine cover.
    • Unscrew 2x bolt
    • Unscrew oil filler cap
    • Remove engine cover
    • Screw in oil filler cap
    4. Remove pollen filter housing
    5. Drain coolant
    • Unscrew coolant compensation tank closure cap
    Warning: Only open coolant compensation tank once engine has cooled down
    • Place collecting basin underneath.
    • Open drain bolt (arrow)
    6. Detach vacuum line
    • Unscrew 2x bolt (arrows)
    • Disconnect 2x hose
    7. Remove charge air pipe (1)
    • Release 2x clamp
    8. Detach engine vent hose
    • Release clamp (1)
    9. Remove air intake hose (1)
    • Remove bolt
    • Release clamp
    10. Detach upper coolant hose
    • Release clamp
    11. Release oil dipstick guide tube at the top
    • Remove bolt (arrow)
    12. Remove connection hose from charge air pipe to intercooler
    • Release 2x clamp
    13. Detach cover
    • Unscrew 3x bolt
    14. Remove coolant pipe assembly (2)
    • Unscrew 5x bolt, nut
    • Release 5x clamps
    • Detach engine transport shackle,
    – Unscrew 2x bolt
    15. Release catalytic converter heat shield (3)
    • Unscrew 2x bolt
    16. Raise vehicle
    17. Detach lower engine compartment cover and right-hand engine splash protection if necessary
    18. Detach catalytic converter heat shield
    • Unscrew 2x nut, bolt
    Note: Unhook heat shield from stud bolt.
    19. Lower vehicle
    20. Remove catalytic converter heat shield
    21. Release metal pipe, exhaust gas recirculation (1)
    • Unscrew 2x bolt
    • Release clamp
    22. Raise vehicle
    23. Remove front exhaust pipe
    Important: When removing the central silencer, a catalytic converter, an exhaust manifold or an exhaust manifold with catalytic converter, the part of the exhaust system remaining in the vehicle must be secured to prevent it sagging. To do this, the section of the exhaust system with the flex pipe contained in it can be fastened to the substructure of the vehicle with suitable means such as e.g. wire or the transportation fittings for a new flex pipe. Bends of as little as 5 - 10 degrees in the flex pipe can lead to damage resulting in total failure of the flex pipe.
    • Unscrew 6x nut
    • Release exhaust pipe bracket
    – Unscrew 2x bolt
    • Remove 2x gasket
    24. Release catalytic converter at the bottom
    • Unscrew 2x bolt (2), nut (3)
    25. Remove catalytic converter
    • Disconnect wiring harness plug (1)
    • Release clamp (arrow)
    26. Remove turbocharger oil return line (1)
    • Unscrew 4x bolt
    27. Detach turbocharger oil feed line (1)
    • Unscrew banjo bolt (2)
    – From cylinder block
    • Remove 2x seal ring
    28. Detach vacuum hose for waste gate unit
    29. Lower vehicle
    30. Remove exhaust manifold (1)
    • Unscrew 8x nut
    • Remove gasket.
    Install
    31. Cleaning work
    32. Install exhaust manifold
    Note: Pour 0.4ml clean engine oil into the oil feed line opening of the turbocharger
    • Replace 8x nut
    • Replace gasket
    • 8x nuts 25 Nm
    33. Raise vehicle
    34. Attach turbocharger oil feed line
    • Banjo bolt 15 Nm
    – At cylinder block
    • Replace 2x seal ring
    35. Install turbocharger oil return line
    • Replace 2x gasket
    • 2x bolts 9 Nm
    • 2x bolts 25 Nm
    36. Connect vacuum hose for waste gate unit
    37. Attach catalytic converter
    Note: Ensure correct positioning.
    • Screw on clamp lightly
    • Connect wiring harness plug.
    38. Attach front exhaust pipe
    • Replace 6x nut
    • Replace 2x gasket
    – 6x nuts 20 Nm
    • Fasten exhaust pipe bracket
    – Tighten 2x bolt
    39. Attach catalytic converter
    • Tighten clamp
    • Tighten 2x bolt, nut
    40. Lower vehicle
    41. Fasten metal pipe, exhaust gas recirculation
    • Replace gasket
    • 2x bolts 25 Nm
    • Tighten clamp
    42. Attach catalytic converter heat shield
    43. Raise vehicle
    44. Fasten catalytic converter heat shield
    • Tighten 2x nut, bolt
    45. Attach engine cover.
    46. Lower vehicle
    47. Fasten catalytic converter heat shield
    • Tighten 2x bolt
    48. Install coolant pipe assembly
    • Attach engine transport shackle.
    – Tighten 2x bolt
    • 5x bolt, nut 9 Nm
    • Secure 4x clamp
    49. Attach cover
    • 3x bolts 9 Nm
    50. Attach upper coolant hose
    • Fasten clamp
    51. Attach oil dipstick guide tube at the top
    • Bolt 9 Nm
    52. Install connection hose from charge air pipe to intercooler
    • 2x clamps 3,5 Nm
    53. Attach air intake pipe to turbocharger
    Important: Adhere to the following installation sequence
    • Place seal on the turbocharger connection
    • Attach air intake pipe
    – Tighten clamp 3.5 Nm
    • Tighten bolt 9 Nm
    54. Attach engine vent hose
    • Fasten clamp
    55. Fit charge air pipe
    • 2x clamps 3,5 Nm
    56. Attach vacuum line
    • 2x bolts 9 Nm
    • Connect 2x hose
    57. Install air cleaner housing
    58. Attach engine cover.
    • Place engine cover in position
    • 2x bolts 9 Nm
    59. Connect battery.
    60. Program volatile memories
    61. Check engine oil level and correct if necessary.
    • Observe specified engine oil quantity
    62. Close bonnet
  7. Thanks JMo thanked for this post
  8. #7
    Regular Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    Quote Originally Posted by C-Owner View Post
    Remove
    1. Open bonnet
    • Unscrew 2x bolt
  9. #8
    May 2011
    South London
    Quote Originally Posted by Damo77 View Post
    I did say
    "for fun"
    So here the pictures just for fun ...........
  10. #9
    18 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Getting that heat sheild out is a pain in the hoop but I have done three, two Astras and one Vectra without removing the front end. I can now do the job on mine in 90-100 minutes but as with PaulHBs I usually allow 4-5 hours.
  11. #10
    Regular Member Teapot's Avatar
    woodbridge, suffolk
    276 Post(s)
    Trim : Design+
    Engine : 1.9 CDTI 150
    Mileage : 101000
    Did turbo replacement on z19dt last summer. took only 5 hours with no prior experience. left rad pack and bumper in place, removed it from under the car. had to disconnect a couple of a.c. pipes but that was no problem as the condenser was knackered so there was no gas in it anyway.
  1. 1.9CDTi Z19DT injector removal
    By 123rado in forum Engine & Drivetrain
    Last Post: 12th April 2013, 08:52
  2. For Sale: Z19dt turbo heatshield
    By tommytonguedj in forum Parts for sale
    Last Post: 4th May 2012, 10:17
  3. z19dth turbo will it fit z19dt
    By zippygsi in forum Vectra C / Signum Troubleshooting
    Last Post: 7th October 2011, 08:04
  4. cdti turbo - 120bhp - z19dt engine
    By djspenna in forum Vectra C / Signum Car Chat
    Last Post: 13th September 2011, 16:03
astra 1.9 cdti turbo removal
vectra cdti turbo removal
z19dt turbo
vectra 1.9 cdti turbo replacement
vauxhall vectra turbo replacement
vectra turbo removal
vectra c turbo removal
vectra c 1.9cdti turbo removal
astra 1.9 cdti 150 turbo
vauxhall astra 1.7 cdti turbo removal
zafira cdti turbo removal
zafira b 1.9 cdti turbo removal
z19dt turbo removal
Vauxhall zafira turbo remove
how to change a turbo on vectra cdti
turbo removal guide 2008 astra cdti
opel vectra 1.9 diesel generator change
change turbo astra
vauxhall vivaro turbo removal
how to change astra h 1.9cdti turbo
z19dt remove turbo
cdti turbo removal
vectra 1.9 cdti turbo removal guide
z19dt turbo replacement
