Results 1 to 10 of 13
Thread: Which socket for top nut on front shocks
    Regular Member pipamish's Avatar
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Default Which socket for top nut on front shocks
    What is that 22mm socket called for the top nut of the shock that holds top mount
    13 Post(s)
    Is it not mentioned in the HOW2?
    Swan neck spanner?
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Oh that's what it's called a swan neck spanner I didn't have a clue what the thing was called and I have never seen one I just know about it lol
    Regular Member megsdad's Avatar
    May 2011
    Northwich, Cheshire..
    25 Post(s)
    Vehicle : Mitsubishi Outlander Phev
    Trim : Full Leather (Heated)
    Engine : Hybrid Petrol/Elec
    Year : 2016
    If you cant get a swan neck spanner to fit use a spark plug socket as i did...its got flats on it !!
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    I have a spark plug socket but I need a special one so I can get an Allen key in the centre of the nut so need to insert Allen key still while tightening
    Moderator paulhb's Avatar
    Wondering lonely as a cloud
    27 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Paul has B6 struts the spark plug spanner won't work as its 21mm suggest you nip to your motor factors the other tool that works a treat are Vortex sockets.
    27 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Its not an Allen key Paul its an T50 torx.
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Vortex that's the ****** I couldn't remember what Ian highlander had said cheers Paul
    Hanging Heaton
    35 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    You can pin the bolt with a screw driver then use an Allen key, this is what I did last time, takes longer like...
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Cool I'm going to buy the proper tool though as I believe my top mount is loose that's why I'm getting a metal squeak
  1. front power socket wiring
    By DeeBe in forum Electrical & ICE (including SatNav)
    Last Post: 19th June 2012, 19:41
  2. Permanent live near front accessory socket ?
    By jon1.9cdti in forum Electrical & ICE (including SatNav)
    Last Post: 14th June 2012, 23:44
  3. front shocks
    By chris1804 in forum Suspension, Wheels & Brakes
    Last Post: 8th May 2012, 06:53
  4. Front Power Socket on CDTi Exclusive ...
    By MrGubby in forum Electrical & ICE (including SatNav)
    Last Post: 4th April 2010, 20:27
  5. Making front aux socket permanently live
    By rheumatoid in forum Electrical & ICE (including SatNav)
    Last Post: 25th January 2010, 11:32
