Results 1 to 5 of 5
Thread: Vectra Sri CDTi 150 BHP
    May 2010
    LU1
    Default Vectra Sri CDTi 150 BHP
    Hi guys just bought a vectra sri cdti 150 bhp. It has 102,000 miles on the clock new turbo full history. I just had a mechanic look at it and he pointed out that the swirl valve is missing near the manifold. Car was sluggish today morning below 2000rpm but after that the car pulls very strong. Do you vectra c owners take this swirl valve off is this normal or was the last owner stupid? is there a easy fix or do i have to replace the manifold? Any suggestions would be great!
    Thanks!
    Apr 2012
    cambridge
    Mines been off for at least 70k, no problems I have noticed, apart from gunky engine and possibly oily smell into cab at times. Sluggishness IMO will be something else.
    May 2010
    LU1
    Cheers will have a look at egr and see if theres any loose pipes
    Regular Member SlowCoach's Avatar
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Engine : Z19DTH
    Year : 2008
    Mileage : 105000
    Quote Originally Posted by SUBEK View Post
    Egr only have one pipe connected to it... Emission inlet pipe at bottom... Blank it. Check egr is clean and functioning.
    Check the unit with blue sticker held by t20/t30 bolt its next to egr in middle of engine manifold...
    Check no split in boost control vacuum hoses,
    Check all jubilee clips for boost, turbo hoses are secure and tight.
    Remember to check air filter and fuel filter.
    May 2010
    LU1
    Thank you
  1. 1.9 Vectra CDTi 150 VS 2.0 CDTi 160 insignia Sri
    By Derek Mc in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2011, 11:38
  2. Vectra 1.9 CDTI Sri Versus 3.0 CDTI V6 Sri
    By collateral in forum Vectra C / Signum Car Chat
    Last Post: 21st April 2009, 20:18
  3. hello all and here's my v6 cdti vectra
    By joebull90 in forum Introduce yourself.
    Last Post: 19th April 2009, 21:14
