Results 1 to 10 of 17
Thread: 16 faults on airbag system
    Mar 2013
    devon
    Vehicle : signum 1.9cdti
    Trim : elite
    Engine : 1.9cdti
    Default 16 faults on airbag system
    well i bought the car as a repaired cat c well i thought i had found most problems but after seeing this it looks like i have alot more digging todo most im hoping are just unpluged and i need to replace ecu with a none crashed one
    now i have been looking for the plug for the temp sensor for a while well i jut noticed this....
    umm now is it me or have they wired the crash sensor into the temp sensor wiring? im guessing i will be fine unwiring it and wiring it back into the temp sensor then find the wires that should be wired to the crash sensor
    Regular Member ThatAudioBloke's Avatar
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    That would certainly account for the B0084s!!
    Did you find a Stetson and a Colt Peacemaker stashed in the car as well??? Looks like the last owner was a full on cowboy!
    Most of those should be "not present" though, so you really should wipe them and see what it comes up with. My bets are that the SRS ECU will report crash data logged (B0051), the front crash sensor might still give B0084-81, especially if they've just lashed on whatever they could find, and you might have to have a look at the cluster to see if the SRS light has been interfered with.
    You probably need a new SRS ECU (or get yours cleared, but 2nd hand tech2 cleared ones aren't massive money), possibly the correct crash sensor (if yours actually is incorrect) and to go over the dash with the finest of fine tooth combs! Make sure that there are actually airbags fitted behind it, for one!!
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Go into actual data an see what it's reading ohms wise for each one
    Try clear codes see what ones come back up.
    Reset crash data to ensure its all fine
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    @plasma @paulvectrac @AntSSSS
    any input on this one lads?
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    You have a crash code in there - that can only be reset by a Tech II/III - even my Genuine Vaux-Com cant clear crash codes I don't think...
    Middlesex
    Trim : SRI
    Mileage : 100k
    Administrator plasma's Avatar
    On the Forum
    540 Post(s)
    Engine : 150
    Mileage : 74000
    Same advice as Critch and Antsssssss
    clear all codes, see whats still active then repost with new findings, we cant tell from that really what is still active and what isnt. But as was stated all airbag circuit on data blocks should read less than 3ohm, it reaches about 2.5 or something and it flags a fault...
    and get tech2 to clear the crash status as well.
    and OMG just saw the crash sensor, that last guy must of tied his horse up before working on that one and then riding off... All airbag cabling is normally an orange colour... that would explain the incorrect EFS as well
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    omfg as above pal thats had a fair wack i bet and as the lads say cowboy is being nice total dick springs to mind and as said only tech2 can clear crash codes ect
    Mar 2013
    devon
    Trim : elite
    Engine : 1.9cdti
    well just been out for another look and i can now see that all 4 pretensions have gone off and i already new the drivers air bag had so thats 5 things i need to buy i tryed to clear the faults but still have the same 16
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    wouldnt like to ctash in that lmao needs tech 2 mate not the unspeable
  1. OP-COM faults
    By WoodleySaint in forum Vectra C / Signum Troubleshooting
    Last Post: 1st June 2012, 16:36
  2. faults
    By steelee in forum Tuning
    Last Post: 23rd November 2011, 00:46
  3. AIRBAG light .. is thier a fuse the the Airbag ecu ?
    Last Post: 10th September 2011, 13:21
  4. Airbag replacement - NSF (front passenger airbag)
    By Caveman_nige in forum Bodywork & Interior
    Last Post: 19th February 2011, 21:12
  5. VEC FAULTS X2 Anybody help???
    By DonMafia in forum Introduce yourself.
    Last Post: 25th January 2009, 17:02
vectra c crash sensor
signum 2007 front airbag sensor
